oil-based poly - satin over semi-gloss?
Forum topic by JeffP posted 10-26-2015 12:31 PM 997 views 0 times favorited 8 replies Add to Favorites Watch
View JeffP's profile
573 posts in 1325 days
10-26-2015 12:31 PM
Topic tags/keywords: finishing
First, this is not about a fine woodworking project. I have an old Ikea dresser in a spare bedroom that has fallen victim to various abuses over the years. I decided on a whim to lightly sand the top and apply some new finish just to make it a little less ugly.
I had some minwax poly laying around and it was semi-gloss. Really wanted to go with less sheen than semi, but it was sitting there and it was “free”. Figured I could just buy some less glossy and do a second coat with that if it was too shiny.
Well, you guessed it. The semi turned out to produce a very glossy result, and I bought a can of satin and put a coat of that on it…doesn’t seem like it knocked down the sheet AT ALL.
So, I’m wondering…is the notion that a lower sheen poly over a shiny poly will knock down the sheen just broken? Does that not work in general? Or does it take a bunch of coats?
Should I just forget about “building up a lower sheen” with a few more coats and go ahead and sand the sheen off and start over? (being very careful not to sand through the paper-thin veneer)
note: both the semi-gloss and the satin are “fast drying” oil-based minwax poly from Lowes.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
8 replies so far
View chrisstef's profile
17252 posts in 2940 days
#1 posted 10-26-2015 12:53 PM
Take a paper bag and rub it over the top just like you were sanding once the poly dries. That should knock down the sheen for ya.
16273 posts in 4152 days
#2 posted 10-26-2015 01:14 PM
Are we talking brush-on? Applying one coat of satin over a semi-gloss should give you satin. Maybe the satin is just still glossier than you would like. You might try one more coat to see if it makes a difference, but you definitely don’t need multiple coats.
If that doesn’t work you can try the paper bag trick chrisstef recommended, or buff with 0000 steel wool.
View OggieOglethorpe's profile
1276 posts in 2044 days
#3 posted 10-26-2015 01:38 PM
Stir them well! Unstirred satin and semi-gloss finishes are just gloss with a slurry of flattening agent in the bottom.
View splintergroup's profile
1934 posts in 1156 days
#4 posted 10-26-2015 02:01 PM
Oggie is right, semi-gloss and satin have silica added as a flattening agent and this stuff settles out and requires a good mixing before use.
Normally I find it much better to use gloss, then flatten it out with the 0000 wool followed by a brown paper bag polish. The silica will obscure the grain and make the finish appear foggy. In you case (just want a quick finish), mix it up good, then apply. If it is still too glossy, try the steel wool.
#5 posted 10-26-2015 03:26 PM
Ahhhh, I see. It “looked ok” in the can, so I didn’t bother to actually stir it with a stick.
This will likely solve the problem. If not, I’ll use the other techniques suggested.
This forum is awesome!
View Clint's profile
3 posts in 790 days
#6 posted 09-06-2016 09:46 AM
Some really knowledgeable woodworkers on this forum. Hopefully y’all can help me. I have been given a five gallon container of oil modified polyurethane gym floor finish. Really good product but has a very high gloss. It has it’s place on some projects but I would like to flatten it some to a satin if possible. I called the mfg. and the tech there didn’t have a clue and doubted it could be done since it was a specialty product designed for one purpose. Being a hard head set in my ways I have a problem with that answer and believe anything can be modified or adjusted. Hopefully someone on here can prove me right. I have tried using 1/3 poly, 1/3 BLO and 1/3 mineral spirits. That toned it down but not to the level I was hoping for. Any suggestions other than #0000 steel wool till my arm falls off?
-- Clint, Florida
View OSU55's profile
1574 posts in 1923 days
#7 posted 09-06-2016 11:54 AM
Clin is it oil or water based? Target coatings sells the flatting agent for their wb coatings. You may have to call, I couldn’t find it on the website. I haven’t tried it in ob but it may work.
View Cooler's profile
299 posts in 777 days
#8 posted 09-12-2016 07:59 PM
- OggieOglethorpe
That was my first reaction. I only use the satin or semi-gloss for the final coat. It gives a nicer effect because the finish is not so cloudy.
Also, elbow grease with 600 or 800 grit wet or dry might be an alternative.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
