Angles and curves
Forum topic by BoomWood posted 10-26-2015 01:01 AM 1005 views 0 times favorited 14 replies Add to Favorites Watch
View BoomWood's profile
BoomWood
44 posts in 911 days
10-26-2015 01:01 AM
Is there anywhere I can find angle and curve templates? Being new to woodworking, and not being a great artist makes it difficult to design my own projects. Is there a website or easy program I can use to draw up curves?
14 replies so far
View conifur's profile
conifur
955 posts in 1058 days
#1 posted 10-26-2015 01:03 AM
What about French Curve templates draftsmen use?
View bearkatwood's profile
bearkatwood
1478 posts in 918 days
#2 posted 10-26-2015 01:11 AM
Here is a set of steel french curves at Highland
http://www.highlandwoodworking.com/sterling-tool-works-roubo-curves.aspx
-- Brian Noel
View SuperCubber's profile
SuperCubber
1015 posts in 2191 days
#3 posted 10-26-2015 01:32 AM
http://www.michaels.com/10064669.html#q=French+curve&start=1
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View MrUnix's profile
MrUnix
6355 posts in 2105 days
#4 posted 10-26-2015 01:36 AM
It would be helpful to know exactly what it is you are trying to do… using a solid template (like the french curves mentioned above) to mark the wood with, or something you print out to use as a pattern (you mentioned ‘website’ or ‘program’). The french curve things have been covered above. If you are looking for a program, just about any graphics program will fit the bill (MS Paint, Gimp, Inkscape, etc..)
BoomWood
#5 posted 10-26-2015 02:02 AM
All good suggestions, thanks! Right now just working on small things like bandsaw boxes and small candle holders. I would like to build a gentleman’s stand next, but want to incorporate curves which is proving to be difficult cutting perfect and matching curves. I also tried drawing some scroll saw plans but my drawing is lacking.
View Betsy's profile
Betsy
3391 posts in 3802 days
#6 posted 10-26-2015 02:23 AM
Before i discovered french curves and templates – I used my kitchen for “templates”. Small round plates, large plates, glasses, measuring cups – all made great “templates”.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View Jimbo4's profile
Jimbo4
1603 posts in 2669 days
#7 posted 10-26-2015 02:34 AM
Staples and/or Office Max.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View Monte Pittman's profile
Monte Pittman
28190 posts in 2245 days
#8 posted 10-26-2015 11:27 AM
- Betsy
I have several cans and dishes in the shop that serve as my templatesfor circles and arcs.
-- Mother Nature created it, I just assemble it.
View Tennessee's profile
Tennessee
2745 posts in 2421 days
#9 posted 10-26-2015 11:38 AM
I have a set of plastic French curves that must be almost 30 years old. Almost every guitar and bandsaw box I build sees those at some point. I like the plastic since I can see through it somewhat.
View MrFid's profile
MrFid
873 posts in 1811 days
#10 posted 10-26-2015 12:06 PM
As for difficulty cutting and matching curves once you’ve drawn them, if you have a bandsaw and an oscillating spindle sander, the job is easier. Cut to the waste side of the line, and inch up to the line with your sander. If you lack either or both of these tools (I lack a bandsaw, currently), the work can be done with a jigsaw, or you can turn your drill press into a spindle sander. If you lack a drill press AND a spindle sander, buy a drill press.
-- Bailey F - Eastern Mass.
View dhazelton's profile
dhazelton
2689 posts in 2203 days
#11 posted 10-26-2015 12:11 PM
Staples, Michaels or A.C. Moore.
BoomWood
#12 posted 10-26-2015 05:56 PM
I have a bandsaw and drill press with spindle sanders. I will definitely get a french curve set and see how that goes.
bearkatwood
#13 posted 10-26-2015 06:07 PM
Whenever I make curves that are larger than a french curve I use trammel points. I have a set from rockler that I really like;
http://www.rockler.com/trammel-points-kit?source=googleps&utm_source=GoogleBase&utm_medium=organic&utm_campaign=Google&sid=V9149&gclid=Cj0KEQjwnrexBRDNmZzNkf7c4c4BEiQALnlxhaSMInaIbS5wYcXbyAOMqXo3FZ7JL5Ey7F5dBJUlA3kaAnl48P8HAQ
Or you can tie a string to both ends of a yard stick and tighten it until you get the curve you want.
-- Brian Noel
View helluvawreck's profile
helluvawreck
30163 posts in 2773 days
#14 posted 10-26-2015 06:11 PM
You can find them on Ebay along with drafting instruments.
helluvawreck aka Charles
