Craftsmen planer/jointer parts
Forum topic by Schaef posted 10-24-2015 07:58 PM 525 views 0 times favorited 1 reply Add to Favorites Watch
View Schaef's profile
Schaef
1 post in 818 days
10-24-2015 07:58 PM
I need a plunger assembly # 21440 for model # 113.20650. Sears parts direct indicated not available.
1 reply so far
View MrUnix's profile
MrUnix
6192 posts in 2072 days
#1 posted 10-24-2015 08:17 PM
Can’t help on finding an OEM part, but that ‘plunger’ is not needed for operating the jointer… it’s just an ‘autostop’ type pin that positively locates the fence at 90 degrees (or maybe 45, both are similar). From the looks of it, it seems like a substitute could be made pretty easily – maybe even just a 16P nail stuck in a wood dowel :) Until then, a drafting 45/45/90 drafting square or similar can be used to set the fence – just position it and lock it down with the knob.
You might want to search over at OWWM to see if someone has one – post a wtb ad in the BOYD section or see if someone is parting out a similar model jointer. That part was used on more than just the model you have.
PS: Setting the fence angle is not something that most people do often – unless you do your edge bevels on the jointer instead of a table saw or other method. Once you set it at 90 and lock it down, you will probably never touch it again… which sort of makes that autoset pin irrelevant.
