Small Shop, Air Filteration and keeping warm
Forum topic by tncraftsman posted 12-11-2009 04:21 PM 1846 views 0 times favorited 16 replies Add to Favorites Watch
View tncraftsman's profile
92 posts in 3075 days
12-11-2009 04:21 PM
Topic tags/keywords: question
The first cold snap is coming through my region and I’m looking for some ideas as how I can keep my shop warm. If you look at my profile, I’ve got a small 10×12 shop which doesn’t have any mechanical air filtration. So far I’ve been keeping my doors open and fan on to keep the shop ventilated. With winter coming in and commissioned projects to make I’m looking for some ideas on keeping my shop warm.
Do you know if space heaters are safe in the shop? Also, will I need to put in air filtration before putting in a heating element? I know propane or kerosene is out because of the exposed elements. I have a small space heater in my home office which blows hot air.
I think that would be safe but want to know what the experts think.
16 replies so far
View RetiredCoastie's profile
999 posts in 3119 days
#1 posted 12-11-2009 04:27 PM
The heater is an issue I’m trying to sort out myself, I’ll probably go with NG radiant (most cost efficient to operate). I built an air filter for very little money. Here is the link, works great! I hope this helps.
-- Proud Supporter of Homes For Our Troops
View gbvinc's profile
628 posts in 3882 days
#2 posted 12-11-2009 04:33 PM
I use a Hot OneĀ® 240 volt heater mounted on the wall to keep me toasty. Should heat a shop the size of yours nicely. You can see it on the wall in the fourth photo of my workshop. The heating elements are sealed in, so no problem with dust, etc.
View DannyBoy's profile
521 posts in 3801 days
#3 posted 12-11-2009 04:52 PM
I keep my eyes open for a small, old wood stove. I’d love to keep one in the corner of my shop to use up wood scraps. The added benefit for me would be since my shop is in the basement, this would help heat the house a little.
-- He said wood...
View Shamus's profile
16 posts in 3053 days
#4 posted 12-12-2009 02:23 AM
A space heater should work if you can get enough BTU’s for that space. And then there’s the cost.
You mention “exposed elements” with kerosene and propane. I’m not sure I understand what your saying here? Is this because of paint or thinner your using or that your concerned about sawdust catching fire?
As mentioned above, I have a franklin stove that takes 20 minutes to get the shop up to 60 when it’s 20 outside. I enjoy the morning’s coffee waiting for it to heat up me and the shop. I’m heating 1200 SF.
View SnowyRiver's profile
51457 posts in 3416 days
#5 posted 12-12-2009 03:47 AM
I use a Modine Hot Dawg natural gas heater. Works great. I have a thermostat on it and usually leave the temp at about 50 degrees, but raise it to 55 or 60 when I work in there.
-- Wayne - Plymouth MN
View BlankMan's profile
1490 posts in 3289 days
#6 posted 12-12-2009 03:54 AM
I too use a wood stove in my shop. It’s in the basement but like now with this cold snap (single digits, no digit the other night) it’s down in the 50’s there and that be a wee bit to chilly. I can handle mid 60’s but not mid 50’s.
-- -Curt, Milwaukee, WI
View russv's profile
262 posts in 3105 days
#7 posted 12-12-2009 05:11 AM
come on, that’s Tennesse. if i had your weather, i’d have my doors wide open year round. lol
seriously, in a mild temp area and a small shop area (120 sq ft), hang a small heater on the wall or from the ceiling so it doesn’t take up space. turn it on 10 minutes before you start working. if you lived where it gets down to 0 degrees, then you might want to maintain a constant temp. keep it small and simple.
-- where to go because you don't want no stinking plastic!
View flyingoak's profile
68 posts in 3044 days
#8 posted 12-12-2009 05:35 AM
I use an oil filled heater. it works like a radiator. it has no exposed heating element which can cause problems not to mention smelling when the dust burns off. it has a thermostat and has an economy mode. i keep it on almost all winter. I use the lowest setting to keep the temp up to about 40 so the finishes stay warm and it heats the shop quickly Incidently my shop is 17 X16
you can pick them up a lowes for about $40
-- where is the duct tape.....
View dbhost's profile
5687 posts in 3168 days
#9 posted 12-12-2009 06:01 AM
I have a Lakewood oil filled electric radiator. It keeps my garage workshop nice and toasty (short sleeve, almost shirtless kind of warm) on the medium setting. They are dirt cheap, and don’t take up much floor space.
-- My workshop blog can be found at, YouTube Channel
View John Gray's profile
John Gray
2370 posts in 3821 days
#10 posted 12-12-2009 06:06 AM
An Oil Filled Heater is my suggestion, I agree with the 2 posts above.
#11 posted 12-15-2009 05:16 AM
Oil might be the way to go. I have a small heater like the Hot One but doesn’t crank out the heat. These are some great ideas
View hairy's profile
2632 posts in 3468 days
#12 posted 12-18-2009 03:28 AM
Quartz halogen shop lights put out more heat than light. They won’t get it toasty, but it might take the nip out of the air.
-- My reality check bounced...
View Padre's profile
930 posts in 3425 days
#13 posted 12-18-2009 03:34 AM
I use a Hotdawg also. Love it.
-- Chip ----------- 6:8
View 8iowa's profile
1572 posts in 3697 days
#14 posted 12-31-2009 03:48 PM
While there are good suggestions here, we need to keep in mind the fact that tncraftsman only has 120 sq ft in his shop. Here in Gainesville the winter nights often slip down into the 30’s or 40’s. I use a small (about 1 ft sq) ceramic electric heater in my garage. It has both a HI and LO setting. This heater is extremely portable, and thus can be moved out of the way when necessary.
View juniorjock's profile
1930 posts in 3701 days
#15 posted 01-01-2010 03:45 AM
My shop is about the same size as yours. Last year I installed a medium sized electric heater with a blower on it. It did pretty good, but doing a lot better since I’ve put up insulation. The insulation is a must. You guys may think it doesn’t get cold in this part of the country, but let me tell you…........ it does!
