New motor for Delta bandsaw
Forum topic by Carl Harada posted 10-23-2015 12:25 AM 638 views 0 times favorited 4 replies Add to Favorites Watch
View Carl Harada's profile
Carl Harada
17 posts in 1355 days
10-23-2015 12:25 AM
Hey guys and gals!
I purchased my first bandsaw recently, a Delta brand which came with the original 1/2hp motor.
Along with some upgrades of a new fence, carter guides, riser block, etc, I bought a 1HP Leeson TEFC motor. The one I picked out did not come with thermal overload. Do you recommend I purchase a thermal overload switch or will a standard mag switch be fine?
Thanks for your thoughts,
-- John 3:16
View TheFridge's profile
9060 posts in 1416 days
#1 posted 10-23-2015 12:55 AM
Supposed to have a Thermal OL sized per motor FLA. Usually adjustable unless the OL unit comes with heaters. Would probably be fine without if you don’t work the hell out of it.
View WoodNSawdust's profile
1417 posts in 1107 days
#2 posted 10-23-2015 01:07 AM
Some thermal overloads work as part of the on/off switch the other kind is built into the motor. In either case you can get by without one. The danger is overload / overheating of the motor, switch, and / or wire. If you are careful nothing will go wrong.
Carl Harada
#3 posted 10-23-2015 01:44 PM
Thanks for the quick replies.
-- John 3:16
View rwe2156's profile
2834 posts in 1411 days
#4 posted 10-24-2015 10:44 AM
I’ve run lots of machines with non-OL motors better to have it but if not you just have to use your head when operating.
Since its pretty easy to bog a 1 HP bandsaw I would want it protected. I would check into the switch.
