Paint/finish question
Forum topic by WillInTheMill posted 12-11-2009 01:10 AM 953 views 0 times favorited 3 replies Add to Favorites Watch
View WillInTheMill's profile
WillInTheMill
54 posts in 3176 days
12-11-2009 01:10 AM
Topic tags/keywords: question paint finish
Hi everyone,
I am about to complete my first side table project. I built it out of Pine, because I plan to use this as a test and then make some nicer ones out of a nicer wood now that I have learned a few things and made a few mistakes. :-) I have finished it so far with primer and one coat of interior paint. Is there anything else that I could put on the table top and the inside of the drawer to prevent scratches or wear over time? It will be a bedside table in our guest room, so it won’t get very heavy use, but I would of course like to keep it looking nice. I don’t want to add a piece of glass or anything like that, but are there top finishes that you recommend that I put on over the regular paint? Something that brushes or sprays on? Thanks in advance for your help!
-- Will, Tampa, FL
3 replies so far
View scrabby's profile
scrabby
42 posts in 3186 days
#1 posted 12-11-2009 02:00 AM
Will, I recommend three coats of poly-acrylic blend top coat (aka water-base poly). It can be easily applied with a foam brush, dries within a few hours, and little odor if that matters. For best results, sand (hand or ROS) with very fine (320+) paper between coats after the coat hardens.
-- Jim, North Vancouver, BC
WillInTheMill
#2 posted 12-11-2009 02:25 AM
Thank you! That’s the kind of info I’m looking for! Is there a particular brand that works best? Will it have a sheen to it? In other words, would I have to apply it to the whole project, or would just the top look okay?
-- Will, Tampa, FL
scrabby
#3 posted 12-11-2009 02:44 AM
Minwax, Varathane, and General Finishes all make good quality poly-acrylic blends in both satin sheen and semi-gloss version (you need to use a poly-urethane or varnish to get higher gloss levels, I find). Different gloss levels on the same project would be noticable, of course – I typically do 2 coats (in the same day) on the base of a table or cabinet, and then 3 – 4 coats on the top.
