| Forum topic by Mike Gager | posted 1258 days ago | 1424 views | 0 times favorited | 10 replies | ![]() |
1258 days ago |
trying to work out how im going to run my dust collection system and ive found the easiest and probably the best way for me to make a few of the runs is along the floor rather then from the ceiling. the hoses would cross over a walk area to get to all my machines my question is whether anyone has their system run this way and if you find yourself tripping over the hoses a lot? is there a way to do this without creating a tripping hazard? |
10 replies so far
#1 posted 1258 days ago |
I have some of my piping running on the floor and some on the ceiling. I put the runs on the floor out of the way of my main walk-way areas. I don’t really even think of them anymore, just step over them when I need to. |
#2 posted 1258 days ago |
I have a portable system and a small shop where everything (but me) is on wheels. I have to run the hoses across the floor and no matter how you slice it, they are a hazard. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#3 posted 1258 days ago |
I run my DC on the floor because my ceiling is low in my garage shop. For the most part, my main line runs in front of my table saw and router table so it is out of the way. I do have, however, a detachable extension run that is mostly ridged pipe with some flex hose at either end. I use it to bridge the other side of the shop when I am planing and jointing, and I remove and slide it in front of my table saw when not in use. You can kind of see in this picture. If you look carefully in front of the table saw, under the outfeed table, you can see the extension stowed away. When in use, it goes across where the yellow DeWalt Vac is. Let me know of you are interested in more; I can get better photos. -- Brian Havens, Woodworker http://brianhavens.com |
#4 posted 1258 days ago |
It works fine in my shop. It’s a good idea to be careful where you walk anywhere. I got use to it with no great difficulty and have never tripped or fallen because of it though I’ve come close a time or two. |
#5 posted 1258 days ago |
Mike, I run the hoses on the floor as well. Like everyone else, I have gotten used to it but occasionally do step on the hoses. But with the way my shop is currently structured there really isn’t any other way to do it. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#6 posted 1258 days ago |
I had a 4” pipe running across the floor in the aisle from my bench to my table saw for years before I went to 5” pipe and then ran that overhead, can’t remember tripping on it even once. But the downside was it cut off rolling mobile base machines through there so you have to plan for that if you use pipe and not hose or don’t have some sort of quick release method to temporarily get it out of the way. -- -Curt, Milwaukee, WI |
#7 posted 1258 days ago |
I made mine like this with 2 zones to reduce the loss of suction on my 2 hp cyclone system. Bob -- A mind, like a home, is furnished by its owner |
#8 posted 1258 days ago |
Mike, -- How am I doing? Better than I deserve. Dave Ramsey |
#9 posted 1257 days ago |
I’m just sorting out duct runs for fitting out my shop in the past week or so. Some thoughts and issues that i’ve come across on duct runs that i’d not expected include: 1. It’s been possible except in one case to find machine locations which keep the ground level runs fairly short, and out of normal walkways. i.e. dropping down the walls in dead areas to the rear of the planer thicknesser, bandsaw, drill press and spindle moulder. (duct runs are probably one reason to keep these fairly close to the walls) 2. My ceiling joists are about 2500mm above the floor, low enough that care is needed to leave the ceiling clear in the assembly area, and on the routes in and out of the shop – so that the head clearance won’t be reduced even more, and so that high pieces won’t clout the ducts. Luckily i can place the main duct between two joists where it crosses the access route. Running between joists sounds like a great idea, but in practice it doesn’t work most of the time. 3. There’s a view that makes sense that says that floor ducts are not a good idea – at least not unless you have lots of experience with the shop layout, and are sure of your machines and their locations. This because no sooner do you get set up but you realise you need to move a machine. 4. The other machines have not been too bad, but the panel saw does not lend itself to dropping a duct down from ceiling level close by – there’s just too much space needed to handle sheets. The sliding table side is a no go as it needs over 8ft of clear operating space to the LHS, and to the infeed and outfeed ends. Even on the RH rip side you’ve got to get out quite a long way if you want to retain a decent 4 ft rip capacity. Stepping just outside of that would drop the duct down into the walkway behind, which means it’s necessary to go even further to the other side of the walkway to the wall. (that’s my one instance of a duct on the ground crossing the walkway) The theory is that you minimise duct runs and bends to maximise dust system performance. This is of course true, but the above tends to have a price in terms of increasing the both the runs and the number of bends. e.g. a duct coming down the wall has got to get to the wall, come down it, return to parallel to the floor, and then get to the machine. On hoses on the ground. This will be my first ducted system, i’ve run for quite a few years with a mobile 1hp filter and chip collector which meant i always had hoses on the floor anyway. It’s not that big a deal, although it’s a bit of a question of exactly where and how many too. A rigid duct might not be such a good idea though, as an accidental kick could ding it pretty badly. These are all reasons i guess why it’s well worth figuring out your duct runs (layout drawing and paper cut outs, or cad) before you finalise the spec of your fan and cyclone/filter system. MIne will be fine as i have a 5hp 16 in Bill Pentz/Clear Vue fan, but on the other hand there’s despite a lot of care quite a bit more pressure drop than originally expected as a result of forced changes to the layout. (one 90 deg bend for example is equivalent to around 12 ft of straight run) The devil (as they say) is always in the detail… ian -- Late awakener.... |
#10 posted 1257 days ago |
Sorry—- I can’t help you at all. My main trunk line runs around the wall next to the ceiling, and I have a drop-down 4” line to each machine, so I have no lines on the floor at all. Like the others have said, just be careful and don’t trip over them. Also as stated above, if your machines are mobile, you’ll have to dodge them some how, or make a path to move the machines if you have to. God luck. Keep on keeping on. -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3547 |
15776 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
