Clear coat for this project, which product?
Forum topic by skogie1 posted 10-22-2015 01:08 PM 758 views 0 times favorited 8 replies Add to Favorites Watch
View skogie1's profile
skogie1
105 posts in 1235 days
10-22-2015 01:08 PM
This is an old frame I found in the trash. I’d like to prep it and hang it with photographs in the open spaces. I like the beaten up rustic look of it and just want to sand it down to get rid of the loose paint and then seal it up with some sort of clear coat. I was just going to use a wipe-on Poly but thought I’d get people’s opinions. It will be inside the house. What would you use? Thanks in advance.
8 replies so far
View Redoak49's profile
Redoak49
3004 posts in 1860 days
#1 posted 10-22-2015 01:12 PM
I would mask off the glass and then use a spray can. If you want a gloss look shellac or lacquer from a spray can will work. For a semi gloss or satin you could use a polyurethane spray can.
View jdh122's profile
jdh122
969 posts in 2689 days
#2 posted 10-22-2015 01:17 PM
I’d probably leave it as is (after cleaning it up and sanding carefully). Any kind of clear coat is going to add gloss, which for me is going to look odd with that rustic look.
Lead in that paint might be a worry – a reason to be careful when scraping and especially sanding. And possibly a reason to want to clearcoat it, I suppose.
-- Jeremy, in the Acadian forests
4826 posts in 2364 days
#3 posted 10-22-2015 02:38 PM
I think I’d pass on the lacquer if some of the old paint stays on. The lacquer solvents may attack and wrinkle it. I think my choice would be a rattle can coat or 2 of shellac. Using a wiping finish on a surface that rough would be very tough to do (well).
skogie1
#4 posted 10-23-2015 12:14 AM
Thanks guys. I think I’ll try a shellac on the backside and see what it looks like.
View bubbastinks's profile
bubbastinks
20 posts in 1237 days
#5 posted 10-23-2015 02:24 AM
I like to use shellac for projects like this as well. Sometimes I’ll add a bit of amber shellac to clear for a bit more depth. After the last coat cures, I’ll often rub it out with 0000 steel wool and wax. Makes for a really nice rustic finish that feels relatively nice as well..
View dhazelton's profile
dhazelton
2650 posts in 2168 days
#6 posted 10-23-2015 12:58 PM
ANY coating on there will darken the bare wood significantly. I’d leave it alone.
View bonesbr549's profile
bonesbr549
1469 posts in 2938 days
#7 posted 10-23-2015 01:26 PM
I’m with the others leave it be. If you must spray, decide if you want high gloss, or a low luster. Shellac is pretty safe and easy to remove. Poly will make it look plastic (IMO)
View Bill White's profile (online now)
Bill White
4820 posts in 3832 days
#8 posted 10-23-2015 02:34 PM
Coatings don’t have to be glossy. If you choose to coat, use a “flat” or “satin” finish.
Water based finishes will not yellow.
Shellac is gonna be glossy.
Bill
-- bill@magraphics.us
