Epoxy for Filling Cracks?
Forum topic by bannerpond1 posted 10-22-2015 12:15 PM 2410 views 0 times favorited 18 replies Add to Favorites Watch
View bannerpond1's profile
397 posts in 1834 days
10-22-2015 12:15 PM
What’s a brand name and source for the epoxy which can be used with metallic flakes to fill cracks in wood?
Thanks for the help.
-- --Dale Page
18 replies so far
View mahdee's profile
3853 posts in 1703 days
#1 posted 10-22-2015 01:19 PM
You can use any of them that claim it adhere to wood, metal, ceramics, etc.
If it is a large project, HD has 4oz (I think) bottles; one for hardner and one for resin. I have used it on wood, metal, etc and it works very well. The trick is to ensure that you are using an equal amount and stirring it thoroughly but not too long (5 minutes epoxy)
View BurlyBob's profile
5309 posts in 2201 days
#2 posted 10-22-2015 02:45 PM
You might check Jamestown distributors. It’s a boat/marine outfit. They’ve got a couple of epoxy resin systems. I’ve bought a couple of things from them and they’re very helpful over the phone.
View Randy_ATX's profile
875 posts in 2377 days
#3 posted 10-22-2015 02:46 PM
I have used this product for years. Watch for Michaels 50% off coupons and use for the larger sizes of this. Practice on some scrap to get experience with it. I like putting copper flakes in the void then filling with epoxy.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
#4 posted 10-22-2015 03:12 PM
I used the same stuff Randy is talking about to fill knot holes in a head and footboard. What I liked was that any air bubbles weren’t trapped in it like the Gorilla glue epoxy I tried.
View Tennessee's profile
2828 posts in 2450 days
#5 posted 10-22-2015 04:42 PM
Bob and Randy – that is an interesting use of that product. I’ve always only used it for the purpose on the face of the box. To build up a thick layer of topcoat quickly. Never thought of it as a filler. Might have to try that.
I agree that epoxy is somewhat harder to work with, especially when it comes to bubbles. Heating it to get bubbles to rise only makes it cure faster. Heating the product you suggest is actually in the instructions, if I remember right, since it makes the bubbles rise to the top and pop off.
Have to rethink this product for uses!
View MrUnix's profile
6498 posts in 2134 days
#6 posted 10-22-2015 04:51 PM
You can get bubbles out of epoxy by vibrating it as well…. can be as simple as hitting the form with a vibrating sander. Heating up the substrate as well as the epoxy will allow it to flow better and reduce the chance of bubbles, and a small torch (propane, butane, etc…) will pop any that rise to the surface. For regular epoxy (not the thickened 5 minute stuff), heating it should not cause any problems with curing too fast. It might knock a few minutes off the wait time for curing, but it will still take several hours to setup, and you will still need to let it sit for 24 hours to fully cure.
Any brand of standard epoxy should work, and almost anything can be mixed in to provide the desired look. I use west system epoxy all the time for filling cracks as well as adding accents and inlays. Here is a bowl I made that uses it for both (filling cracks and a black epoxy inlay around the rim):
The epoxy above was colored black using some of that powdered stuff sold for coloring cement :)
PS: The largish cracks in the two bowls in the background were also filled with epoxy.
View CharlesA's profile
3310 posts in 1733 days
#7 posted 10-22-2015 04:52 PM
I’ve never had bubble problems with 5 minute epoxy. I use the 4 oz separate bottles.
16273 posts in 4154 days
#8 posted 10-22-2015 05:15 PM
As others have said, lots of things will work. As for a specific brand name, I’ve used InLace with good results:
View Drew's profile
350 posts in 3035 days
#9 posted 10-22-2015 09:29 PM
How big of a job?
Loctite 5 minute epoxy works great on small jobs.
The trick though is to warm both bottles BEFORE mixing.
I heat up a cup of water in the microwave, then let both bottles sit in there for 1-2 minutes before mixing.
Be very careful if you add heat after application. The outside can set up fast trapping air bubbles.
A better solution, and my go to epoxy, is No-Blush marine epoxy from epoxy products dot com
View Jim Finn's profile
Jim Finn
2641 posts in 2857 days
#10 posted 10-22-2015 10:40 PM
I use a product called “Z-POXY” that is a finishing epoxy. It is much thinner than any other epoxy I have used. IT is so thin that over time this product will run out the other side of the wood if the crack is all the way through. I put masking tape on the back side of the wood when I apply the Z-POXY so that it will not run out. It does not bubble for me but does take hours to set up. Sands well and color can be added. I have used colored chalk for this. Z-POXY is usually available at local hobby shops.
View Mark Wilson's profile
Mark Wilson
2082 posts in 999 days
#11 posted 10-24-2015 08:43 PM
As others have said, lots of things will work. As for a specific brand name, I ve used InLace with good results:
- CharlieM1958
Now you got me going on another new thing, Charlie. Website, BMd.
-- Mark
#12 posted 10-30-2015 02:53 AM
Thanks to all of you who replied. InLace is what I was looking for, but I found some cheap epoxy at Hobby Lobby in a dual syringe configuration. It’s GREAT!!! I used charcoal powder to color the exopy jet black and fill an inclusion in walnut. Great results.
I’m going back and get several of the two-tube sets. It’s only about $3.50 and I did three projects with it.
-- --Dale Page
View TinWhiskers's profile
179 posts in 888 days
#13 posted 10-30-2015 04:23 AM
Warming the wood will cause the wood to out gas. Thus causing bubbles. I warm my epoxy by bringing to room temperature.
View bonesbr549's profile
1516 posts in 3003 days
#14 posted 10-30-2015 12:05 PM
I’ve used quite a few and system three is a good one, but also used 5min epoxy as well. system is the best.
I work mostly with cherry so when filling cracks or knotholes, I like cryo-cycolate, due to it’s quick set time. I also like when it sets it looks like a pitch pocket. I also like you can use thin or thick versions depending on need, and the use of the accelerator
good luck.
#15 posted 11-10-2015 12:10 PM
Thanks, Bones. I use cherry a lot and usually cut out the pitch pockets. Your idea might save me from making more kindling.
-- --Dale Page
