Need conveyor belt - Kuster Woodworking Ultra Sand 36" dual head thickness sander
Forum topic by GlennsGrandson posted 10-22-2015 12:42 AM 2261 views 0 times favorited 8 replies Add to Favorites Watch
View GlennsGrandson's profile
GlennsGrandson
442 posts in 2212 days
10-22-2015 12:42 AM
Topic tags/keywords: kuster kuster woodworking ultra sand conveyor belt
Hi everyone,
I recently acquired a Kuster Woodworking Ultra Sand 36” dual head thickness sander. This company has been out of business for quite awhile, I think since the late 80’s. It is a solid machine but the feed conveyor belt had broke on it with the previous owner and he was unable to find a replacement so he was just manually pushing the stock thru. I measured what the belt should be and it is about 36” x 72”, with the length give or take an inch because of available adjustment. Does anyone know of any belts this size or where I could have a custom one made? I haven’t had much luck searching the WWW.
Thanks for any input
-- Grant - N Dakota
8 replies so far
View Daruc's profile
Daruc
460 posts in 1036 days
#1 posted 10-22-2015 01:22 PM
View Bill7255's profile
Bill7255
425 posts in 2188 days
#2 posted 10-22-2015 01:27 PM
I believe 2sand makes custom belts. http://www.2sand.com/en/
-- Bill R
View Odd1's profile
Odd1
1 post in 832 days
#3 posted 11-10-2015 06:01 PM
Try shop.fargoindustrial.ca
View CharlesNeil's profile
CharlesNeil
2220 posts in 3774 days
#4 posted 11-10-2015 06:09 PM
contact industrialabrasives.com , they make all sorts of belts
GlennsGrandson
#5 posted 11-11-2015 02:49 AM
Thanks everyone, 2sand didn’t pan out and Apache never got back to me. I’ll try the new recommendations.
-- Grant - N Dakota
View rick1955's profile
rick1955
264 posts in 1334 days
#6 posted 11-13-2015 05:59 AM
http://www.rubbercal.com/specialty-products/woodworking-belts/
This is the kind of belt you want. Meant to convey wood through sanders.
-- Working smarter with less tools is a true crafts person...
GlennsGrandson
#7 posted 04-04-2016 01:48 PM
Rubbercal.com is exactly what I wanted, but the minimum pulley diameter recommended for their belts is 3” and my pulleys are 2”. I contacted industrial abrasives and they were happy to make the belt that I needed. They make it out of aluminum oxide backed 100 or 120 grit sandpaper with a butt joint that they state has minimal height difference. We’ll see, they state that they are 7-10 days out from the finished product and shipping. I also order a roll of 4”x25 yards by 120grit sand paper from them too. The custom belt cost was $40. Excited to see it, hopefully it works. I’ll update when I get it.
And it looks like it’ll be a big undertaking to get the belt on. I’ll have to remove all of drums and guide rollers above to get the table off, slide the belt on (hopefuly) and then reassemble.
Thanks for all of the help.
-- Grant - N Dakota
GlennsGrandson
#8 posted 04-24-2016 08:41 PM
Works like a champ. I occasionally have to help turn the belt by hand, I could probably tighten up the belt but I’m a little hesitant to put that much tension on it and risk ripping it. I hope this forum helps someone else someday.
Video_1461529855076Video_1461529896460
-- Grant - N Dakota
