Kreg jig for building upper kitchen cabinets
Forum topic by HarleySoftailDeuce posted 1256 days ago 8293 views 0 times favorited 13 replies Add to Favorites Watch
View HarleySoftailDeuce's profile
HarleySoftailDeuce
272 posts in 1587 days
1256 days ago
Hello fellow Jumber Jocks,
I’m about to start my upper kitchen cabinets, and am not sure how to proceed. Should I start by building the carcasses first or the face frames?
1 issue I have if I build the FF’s first is they might warp if I do not hurry to follow up with the carcasses, and because I am slow, and have other things pending, would that be an issue to consider?
I suppose it would be easier if I copy the existing uppers as I am still using them, but can get my measurements from them.
Merry Christmas and a Happy New Year to all !
-- Paul, Bristol,Rhode Island
13 replies so far
View cabinetmaster's profile
cabinetmaster
10874 posts in 1725 days
#1 posted 1256 days ago
If you have the room, I would build the carcass first. Then build the FF and put them on the carcass as they are built. I you need more info, feel free to pm me. Been a cabinetbuilder for over 30 years.
27262 posts in 1989 days
#2 posted 1256 days ago
Paul, I agree with Jerry. I always build the carcass first and then fit the face frame to the carcass.
View MDRoehl's profile
MDRoehl
57 posts in 1279 days
#3 posted 1256 days ago
I agree with the others, I always build the carcasses first.
-- Sawdust in my veins--
HarleySoftailDeuce
#4 posted 1256 days ago
Thanks to my friends at LJ !! I’m going to do the boxes first.
Does everyone agree that the Kreg is the best way to build and attach the FF’s?
View mics_54's profile
mics_54
581 posts in 1638 days
#5 posted 1256 days ago
Why on earth would you build a ff first?
kreg…not necessarily.
-- Dan, Sterling Alaska, Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
View TheDane's profile
TheDane
2675 posts in 1830 days
#6 posted 1256 days ago
Kreg is a terrific choice. I have the K3 system, plus a couple of their right-angle clamps … makes face frame and carcase construction much easier.
mics_54
#7 posted 1256 days ago
A kreg pocket hole would be great if you are building modular cabinets on which the faces are mounted prior to installation. They will not be that great otherwise.
86997 posts in 1744 days
#8 posted 1256 days ago
How you attach your face frames can differ according to how your cabinets are configured unless there nailed on . I don’t like the look of pocket screws if they are visible even with plugs the are way to obvious unless you can put them were they wont be seen. you can also kerf the edge of your cabinets large enough to accept biscuits and then add biscuits to the back of the face frame . Of course I agree with making the cabinets first.
View sandhill's profile (online now)
sandhill
1978 posts in 2091 days
#9 posted 1256 days ago
carcasses for sure. I would use pocket holes anywhere they will not show and a biscuit here and there to keep them lined up and if you do not have that tool dowels will work in the corners and longer spans..
#10 posted 1256 days ago
I just remembered a small cabinet I whipped out for a class I was teaching that the very last second I applied the face frame with turners tape ,it stuck very well and is still on the demo cabinet. I’ve thought about using this on a combination of cabinets with one face frame but I have not been brave enough to do this on a customers job.
View Don Newton's profile
Don Newton
711 posts in 1786 days
#11 posted 1256 days ago
As most have already stated, boxes first. To attach the face frames, cut a groove in the edge of the cabinet sides (no need to do the bottoms) and make a corresponding groove in the stiles (veritcal pieces) of the face frames. Attach with glue and splines. This is a very strong method, especially if the doors are to be hinged from the face frame, but you must take care to have the grooves align. Needs some precision but isn’t that what we strive for? Good luck.
-- Don, Pittsburgh
View lilredweldingrod's profile
lilredweldingrod
2498 posts in 1274 days
#12 posted 1256 days ago
If you use the Kreg system, be sure you clamp the FF or when you put the screws in, the board will move slightly and botch the look with a catch edge. A real shame to do all that work and have it look like I did it.
Rand
TheDane
#13 posted 1256 days ago
Rand is right … that is why I bought the right-angle clamps. Norm Abram did a whole series a year or so back on a kitchen remodel. He used pocket-screws to assemble the face frames, then used biscuits to attach them to the carcases. He used his PC biscuit joiner to on the frames, but used a router with a slot-cutter to make grooves in the carcases.
