sanding
Forum topic by erika1 posted 10-21-2015 01:23 PM 738 views 0 times favorited 14 replies Add to Favorites Watch
View erika1's profile
erika1
6 posts in 955 days
10-21-2015 01:23 PM
How do I sand this is? The grain goes all different directions!
14 replies so far
View johnstoneb's profile
johnstoneb
2915 posts in 2173 days
#1 posted 10-21-2015 01:44 PM
It looks like you have at least one coat of finish on. Grain direction doesn’t really matter. I usually sand the first coat by hand lightly with 320,400 grit. second coat I’ll go to 600 grit wet or dry and then see how finish looks before deciding what grit to use after that. My finish is always hand sanded.
-- Bruce, Boise, ID
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2370 days
#2 posted 10-21-2015 01:48 PM
First off, is that a veneered piece? If so, you’ll want to be careful about sanding through. What are your goals with this, staining, just refinishing, etc? ROS with a sanding sponge for the edge profiles could work. You may also consider a chemical stripper, but I’m not sure how/if that would effect the veneer?
Edit : Are you looking to sand to level the finish, or to remove it?
View dhazelton's profile
dhazelton
2768 posts in 2297 days
#3 posted 10-21-2015 01:48 PM
If you’re trying to sand the finish OFF use a random orbit sander. If you’re trying to sand between coats of finish then sand in the direction of your brushwork.
erika1
6 posts in 955 days
#4 posted 10-21-2015 01:55 PM
I was told it was oak. I want the finish off. I am planning on staining it.
View gfadvm's profile
gfadvm
14940 posts in 2690 days
#5 posted 10-21-2015 01:59 PM
You are probably better off stripping the finish and then sanding VERY lightly to avoid going through the veneer.
16274 posts in 4218 days
#6 posted 10-21-2015 02:00 PM
A random orbit sander would be the way to go. But like Ed said, if it is veneer you will have a hard time taking all the finish off without sanding all the way through it.
erika1
6 posts in 955 days
#7 posted 10-21-2015 02:04 PM
Im not an expert but I dont think its veneer. Its rock solid and heavy as crap.
View waho6o9's profile
waho6o9
8191 posts in 2577 days
#8 posted 10-21-2015 02:22 PM
Card scrapers
View mahdee's profile
mahdee
3883 posts in 1768 days
#9 posted 10-21-2015 02:49 PM
Mix some stain with poly and mineral spirit, brush it on and wipe off after a few minutes or use polystain.
-- earthartandfoods.com
johnstoneb
#10 posted 10-21-2015 02:53 PM
It’s veneer. I would use a chemical stripper then sand lightly.
-- Bruce, Boise, ID
erika1
6 posts in 955 days
#11 posted 10-21-2015 03:05 PM
Well crap if its veneer I will just use chalk paint or just throw it away
BinghamtonEd
#12 posted 10-21-2015 03:29 PM
It make by rock solid and heavy as crap because it is veneer over some sort of MDF or ply or something. Or, it may be veneer over a solid piece of wood. Either way, I doubt it is a glue up of a bunch of pieces in that configuration. I would think the wood movement would cause cracking.
Flip the table over, what does the bottom look like? Or, if there are screws holding the top to the legs/apron, pull them out, and see what the inside of that top look like. Drill a small hole in the bottom, and see what dust comes out. Number of ways to see what you have there, but my bet is veneer.
johnstoneb
#13 posted 10-21-2015 03:34 PM
There is no reason to throw it out. It looks nice strip it and stain it. See what it looks like then. There is a lot of fine furniture that is veneered.
-- Bruce, Boise, ID
View tomsteve's profile
tomsteve
784 posts in 1219 days
#14 posted 10-21-2015 05:12 PM
this is veneered. i wouldnt throw it out as i wouldnt throw out that table because its veneered. thats a pretty nice pattern on it.
