Turning a Circular Saw Into a Table Saw
Forum topic by wmgworks posted 10-20-2015 03:58 PM 2801 views 0 times favorited 41 replies Add to Favorites Watch
View wmgworks's profile
wmgworks
193 posts in 954 days
10-20-2015 03:58 PM
I’ve been spending a lot of time thinking about a multi tool workbench – one that integrates a miter saw, drill press, router table, etc. I have a small shop so making things multipurpose will be a necessity. As for table saw, the ones I can afford most people seem to think are not that good. I’ve seen lots of really cool ideas on making a table saw station out of a circular saw and I find this very appealing. When shopping around, I’ve seen that most really good quality circular saws are less expensive than decent table saws. I would think a lot of the extra money of a really good table saw goes into the table itself, the fence, the miter gauge and other stuff. A lot of that can be made by hand as well. If I turned a pretty good circular saw into a table saw, what would I be missing out on?
Thanks!
-- Butchering wood since 2015
41 replies so far
View mahdee's profile
mahdee
3874 posts in 1736 days
#1 posted 10-20-2015 04:02 PM
Not much other than you will be limited to the 7-1/4” blade instead of 10”. 10” miter saw mayne another option. In the early 80’s Sears used to sell the table for circular use. I used mine for several years and nothing else making musical instruments.
-- earthartandfoods.com
View BurlyBob's profile
BurlyBob
5424 posts in 2234 days
#2 posted 10-20-2015 04:11 PM
I had one of those Sears tables. It worked decently on small stuff. Your limited by the lack of torque. A circular saw getting it’s cutting power by it’s speed. There’s really no torque. Like I said it worked ok on smaller stuff. I’m much happier with my Delta X5 nowadays.
wmgworks
#3 posted 10-20-2015 04:29 PM
Your limited by the lack of torque. A circular saw getting it s cutting power by it s speed. There s really no torque. Like I said it worked ok on smaller stuff. I m much happier with my Delta X5 nowadays.
- BurlyBob
Ok educate me a bit. How does torque factor into making a cut? Does that mean the less torque you have the harder it is to cut certain materials?
View MrUnix's profile
MrUnix
6609 posts in 2168 days
#4 posted 10-20-2015 04:33 PM
How about a circular saw in a box…
(More info here: http://www.owwm.org/viewtopic.php?f=1&t=161452 )
PS: There is no reason you cant find a nice used cabinet saw for the price of a used C-man contractor saw… you just need to be patient and persistent.
wmgworks
#5 posted 10-20-2015 04:37 PM
^^^^^ That’s really cool! Thanks for sharing it
View johnstoneb's profile
johnstoneb
2871 posts in 2141 days
#6 posted 10-20-2015 04:40 PM
Torque is what in necessary to get something started and to maintain its speed under load. Horsepower will maintain a speed unloaded but drop off rapidly under load.
You are right a lot of the money in a table saw goes into the table, the fence, the miter. Money also goes into the motor and drive system the trunion that holds the blade to the table and allows for different depth on the blade and different angles accurately. Accuracy is something you will struggle with when you try to mount a circular saw on a table.
Even the jobsite saws are better for use as a table saw than trying to adapt a circular saw to a table.
-- Bruce, Boise, ID
wmgworks
#7 posted 10-20-2015 05:08 PM
I should also mention a major limiting factor in my shop and that is power. I live ina townhouse complex where 2-3 of us share a single 20 amp 120v circuit between our garages (since they are on house power). I’ve peeked into my neighbor’s garages and none of them are running anything other than their garage door openers. So I will get the entire 20 amps to myself most of the time. Most of the tablesaws I have been looking at don’t go over 15 amps. Do the higher torque saws require more amps anyway?
View rwe2156's profile
rwe2156
2884 posts in 1449 days
#8 posted 10-20-2015 05:28 PM
Have you checked Mattias Wandel’s video on youtube?
I actually started out ww’ing by screwing a circ saw to a piece of plywood.
Looking back compared to what I have now it was pathetic, but it cut wood fairly accurately.
If I may suggest the ideal ww’ing method of a very small shop person is hand tools.
View Dallas's profile
Dallas
3599 posts in 2456 days
#9 posted 10-20-2015 06:25 PM
WTH?
California has some of the toughest rules for construction in the book.
How would someone reset a circuit breaker if it tripped?
Who pays for the electricity used?
Some of the bigger circular saws draw as many amps as a contractor table saw….
Just some things to think about.
“I should also mention a major limiting factor in my shop and that is power. I live ina townhouse complex where 2-3 of us share a single 20 amp 120v circuit between our garages (since they are on house power). I’ve peeked into my neighbor’s garages and none of them are running anything other than their garage door openers. So I will get the entire 20 amps to myself most of the time. Most of the tablesaws I have been looking at don’t go over 15 amps. Do the higher torque saws require more amps anyway?”
wmgworks
#10 posted 10-20-2015 07:17 PM
Have you checked Mattias Wandel s video on youtube?
I actually started out ww ing by screwing a circ saw to a piece of plywood.
If I may suggest the ideal ww ing method of a very small shop person is hand tools.
- rwe2156
I have seen his videos and that build is amazing! It inspired me to do more research on turning hand tools into stationary ones.
I did woodworking 20+ years ago when I was still in high school. And while I remember a lot of it, there are a lot of things I have forgotten (probably for the better). And I don’t plan on making lots of the same thing at the same time. Mostly one off smallish projects. So, to me, converted hand power tools may be good enough for now, know what I mean?
Hand tools are something I have thought quite a bit about. I’m sure I will build up a collection over time and may even use them more than power tools at some point. But not yet
wmgworks
#11 posted 10-20-2015 07:23 PM
- Dallas
The HOA pays for the house power (garages, outside lights, etc) so they figure that’s all we need for a garage. And for 99% of the people here that’s true. I just have to be difficult.
If the breaker trips, most people call one of a couple people on the HOA board. But, they’ve told me in the past to just go in the box when I had a problem one time. So, if I flip it I can fix it.
wmgworks
#12 posted 10-20-2015 07:25 PM
- rwe2156
I did woodworking 20+ years ago when I was still in high school. And while I remember a lot of it, there are a lot of things I have forgotten (probably for the better). And I don t plan on making lots of the same thing at the same time. Mostly one off smallish projects. So, to me, converted hand power tools may be good enough for now, know what I mean?
Hand tools are something I have thought quite a bit about. Because of he power issue AND because I love traditional techniques. I don’t plan on having more than one tool on at a time. But turing on the saw with the shop vac on may trip a breaker. I don’t know yet. If that happens I will HAVE to switch to hand tools. I’m sure I will build up a collection over time anyway. But not yet
- wmgworks
wmgworks
#13 posted 10-20-2015 07:26 PM
- rwe2156
Hand tools are something I have thought quite a bit about. Because of he power issue AND because I love traditional techniques. I don t plan on having more than one tool on at a time. But turning on the saw with the shop vac on may trip a breaker. I don t know yet. If that happens I will HAVE to switch to hand tools. I m sure I will build up a collection over time anyway. But not yet
View bearkatwood's profile
bearkatwood
1547 posts in 980 days
#14 posted 10-21-2015 12:58 AM
I started out with a jig saw that I screwed upside down to a board and a chop saw. I wish I had not the phobia of hand tools that I did back then or I would have started down the handtool path much sooner. My learning has taught me how to use power tools to their best advantage, but sometimes it is best to unplug. I love that saw in a box, if you could attach it to a workmate it would make a great jobsite/ remodel tool.
-- Brian Noel
View shipwright's profile
shipwright
7967 posts in 2767 days
#15 posted 10-21-2015 01:13 AM
Get a ShopSmith. The best thing going for a small shop.
Check out this blog. http://lumberjocks.com/shipwright/blog/series/4678
showing 1 through 15 of 41 replies
