Marvel 40 router - anyone have opinion ?
Forum topic by cdcjr posted 12-10-2009 04:21 AM 1021 views 0 times favorited 3 replies Add to Favorites Watch
View cdcjr's profile
cdcjr
12 posts in 3859 days
12-10-2009 04:21 AM
Topic tags/keywords: question
To avoid dismounting my Freud router from the router table every time I need to do smaller projects, am considering purchasing a small handheld router. Has anyone had experience with the Marvel 40 ?
-- boonedocks retired doc
3 replies so far
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3226 days
#1 posted 12-10-2009 06:03 AM
I like mine better than my neighbors Bosch palm router, and right now you can save an extra 10 spot. I use this most of the time when I route just because it is so dang handy. The only complaint I have is that the clear plastic base was over tightened at the factory and cracked all around the screw holes that hold the bottom piece on. MLCS did not want the piece back, so I glued a 1/4” piece of plexiglass on drilled to accept a router guide for 1/4 shank bits. I make all my zero clearance inserts for my TS. Watch the video, it comes with all the attachments as well. It’s not bad for the money.
View MarkwithaK's profile
MarkwithaK
370 posts in 3297 days
#2 posted 12-10-2009 06:42 AM
I have the Bosch Colt VS and I’m pretty pleased with it.
-- If at first you don't succeed then maybe skydiving isn't for you.
cdcjr
#3 posted 01-30-2010 05:11 PM
Many thanks for the responses !
