Router Insert Plate- Need advice on making my own
Forum topic by monster1971 posted 10-19-2015 06:30 PM 638 views 0 times favorited 5 replies Add to Favorites Watch
View monster1971's profile
45 posts in 932 days
10-19-2015 06:30 PM
Topic tags/keywords: router insert aluminum insert polycarbonate insert
In the process of converting a workbench into a router table. Have gotten a lot if useful information off of LJ but the one thing I need help w/ is advice on making my own Insert Plate or just biting the bullet and buying. I can get either a blank Aluminum or Polycarbonate 1/4 or 3/8 sheet from the internet for about $25. The one thing that’s an advantage of just buying a pre-made one is the inserts that you can swap out.
I can get the Kreg w/ 3 inserts for $50 from Amazon or a Bench dog for a little more ( 1 insert). I thought by doing it myself I could save some cash but just checking to see if its really worth it.
Anyone made their own or advice on this?
How about inserts?
Aluminum Blank
5 replies so far
View Kaleb the Swede's profile
Kaleb the Swede
1817 posts in 1905 days
#1 posted 10-19-2015 06:33 PM
I am making one of my own right now out of 1/2 inch cutting board I got from a restaurant supply place. I did it so I can have a couple of different sizes all for thirty bucks.
If you get a big enough sheet of the stuff you are using you have material for multiples. I say go for it
-- Just trying to build something beautiful
#2 posted 10-19-2015 07:36 PM
Kaleb, like this cutting board?
View HokieKen's profile
4669 posts in 1074 days
#3 posted 10-19-2015 08:28 PM
I made 2 inserts myself. The first from MDF w/ formica, the second from 1/2” HDPE. Both sagged under the weight of my 3.25HP PC router within a few days. I bought the Kreg plate and after several months, it’s still flat with no sag. If I were doing it all over again, I’d save myself the time and headache and buy one right out of the gate. I’m usually a build-it-myself guy, but in this case, the 20-30 $ it saves just isn’t worth it. Especially with the twist-loc inserts that Kreg has.
That being said, 3/8” aluminum is a solid material choice. PC maybe fine too depending on the router you’re hanging on it.
For inserts, I cut some 3” disks from 3/16 Lexan and cut a rabbet for them in the HDPE plate I made. I seemed to work fine with a little carpet tape to keep them from blowing up. If you do make some, I’d suggest incorporating some kind of hold down method.
Again though, for my $.02, the Kreg plate is a fantastic product and worth every penny.
-- Kenny, SW VA, Go Hokies!!!
View bigblockyeti's profile
5058 posts in 1656 days
#4 posted 10-19-2015 09:48 PM
I made mine from 1/2” lexan. It’s held up well supporting a 1 3/4hp router and a 3 1/2hp router.
View pintodeluxe's profile
5596 posts in 2749 days
#5 posted 10-19-2015 11:16 PM
You might check Bench Dog, they have some really nice aluminum plates. They won’t sag, even with a 13-15 amp router.
