Slab sanding
Forum topic by TinWhiskers posted 10-19-2015 02:22 PM 601 views 0 times favorited 3 replies Add to Favorites Watch
View TinWhiskers's profile
TinWhiskers
179 posts in 857 days
10-19-2015 02:22 PM
I am new to working with slabs. I was wondering if it would be ok to start sanding before I reach 12% moisture content? Itching to get started planeing and sanding. Wood I want to start with is 2” x 18” x 100”. 18% at this point. 30% in the dark areas.
Photo…
https://www.facebook.com/photo.php?fbid=10204539709442816&set=a.10201842203206846.1073741825.1535749101&type=3
3 replies so far
View AZWoody's profile (online now)
AZWoody
1264 posts in 1129 days
#1 posted 10-19-2015 02:25 PM
If it was 18% you might be able to start doing some planing and work on it, depending on what the normal humidity is where the slab will be placed.
30% is pushing it. I think you will have some problems working on it at this point.
View mahdee's profile
mahdee
3844 posts in 1673 days
#2 posted 10-19-2015 02:28 PM
For sure. It is advisable to plane/sand rough cut wood in order to get an even surface which will help wood dissipate moisture more evenly. The main thing is to not get it hot while sanding/planing.
-- earthartandfoods.com
TinWhiskers
#3 posted 10-19-2015 02:33 PM
Outdoor bench with a back. Piece shown is the back rest. North Ohio. I would not add legs or do anything else at this point. Just planing and sanding.
