care for cast iron table top on saw
Forum topic by csifishguy posted 12-09-2009 06:23 AM 7995 views 0 times favorited 11 replies Add to Favorites Watch
View csifishguy's profile
csifishguy
70 posts in 3118 days
12-09-2009 06:23 AM
Topic tags/keywords: question
what is the best way to care for my cast iron table top on my new saw? I now am using wax is there a better way or product.
Thanks
11 replies so far
117120 posts in 3603 days
#1 posted 12-09-2009 06:45 AM
Wax is the way to go just clean it when it gets diry and keep wax on it . you can use car wax, or floor wax.
View Kevin's profile
Kevin
462 posts in 3231 days
#2 posted 12-09-2009 06:55 AM
I use SB Johnson Paste Wax (in the yellow can) from Lowes. I also cover my cast iron machines with thick towels during the winter months because my garage is not heated to try to minimize any rust from getting on them. The wax supposedly helps also.
-- Williamsburg, KY
csifishguy
#3 posted 12-09-2009 03:04 PM
Thanks I like the towel idea , I just do not want to get any rust on my saw, I read some reviews on a product called T 9 , some kind of spray lubricant with a protective coating have any of you ever tried or heard of this.
View Tim_456's profile
Tim_456
170 posts in 3622 days
#4 posted 12-09-2009 05:36 PM
I use car wax on mine to protect it from humidity and just general moisture. If I’m going to be away from the work shop for an extended period of time I have a “cover” my wife sewed up from some camping tarps that are semi waterproof and “fitted” for my saw.
Oh, and since my workshop is in the basement I usually have a dehumidifier going at a slow rate to keep all my stuff dry. Maybe this is all over kill but spending a day cleaning surface rust off a table top rather than cutting wood proves the ouch of prevention motto;)
View PurpLev's profile
PurpLev
8536 posts in 3675 days
#5 posted 12-09-2009 06:37 PM
wax, or you can use Boeshield T-9 which lasts somewhat longer but also more expensive.
I also throw a moving blanket over each machine during long periods of time when I’m not using them to help with humidity and general dust and dirt.
View Ger21's profile
Ger21
1074 posts in 3157 days
#6 posted 12-09-2009 08:32 PM
I use TopCoat. Lasts a long time, keeps it slick and prevents rust.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3133 days
#7 posted 12-09-2009 08:49 PM
You should have very little rust problems in your area. You live in a low humidity zone. Paste wax will do every thing you need and then some. Enjoy the new saw and congradulations, neighbor.
Rand
View interpim's profile
interpim
1170 posts in 3485 days
#8 posted 12-09-2009 09:04 PM
I’ve heard that using car wax is generally a bad idea since the silcone in it will ruin a finish on wood. I use Johnson’s Paste wax for my saw.
-- San Diego, CA
View Planeman's profile
Planeman
97 posts in 3604 days
#9 posted 12-09-2009 09:21 PM
I’ve heard many answers to this. I’ve had my workshop for 50 years with numerous cast iron surfaces including metal lathes and milling machines with no problems. Of course it depends on the moisture and salt content of the air where you live. I live in moisture-laden Atlanta, Georgia USA where you have to cut your way through the humidity in the summer. In all of these years I have used WD-40 which was developed for the U.S. Navy to deal with rust on machine surfaces and I have no problem if it is done properly. WD-40 is made to DISPLACE moisture on metal surfaces. It enters the pores of a metal surface and forces the moisture out, then forms a coating to keep moisture out (I read this on their website). About once a year I liberally spray WD-40 on my cast iron machine surfaces and tools and leave it overnight to do its job. Then I wipe off the surfaces the following day with a paper towel. It leaves no noticeable oily residue, does not soak up into sawdust, and doesn’t get on any wood I work with. No rust in my shop! I’m sold on the stuff.
Planeman
-- Always remember half of the people in this country are below average.
View Jason White's profile
Jason White
114 posts in 3397 days
#10 posted 12-09-2009 10:12 PM
View WilliamEarl's profile
WilliamEarl
7 posts in 3118 days
#11 posted 12-09-2009 10:22 PM
I use a product called Top Coat on all my cast iron surfaces. It is less expensive than T9 and readily available in places like Home Depot. It is not picked up by the wood and will not affect any finishing product you use.
