Bowed board for tabletop
Forum topic by flamingoezz posted 10-19-2015 12:37 AM 590 views 0 times favorited 5 replies Add to Favorites Watch
View flamingoezz's profile
flamingoezz
5 posts in 864 days
10-19-2015 12:37 AM
I’m making a table top and 1 of the 5 boards is bowed a decent amount. if I put a board across the ends of the table top during glue up and clamp at the high point, will it dry evened out?
5 replies so far
View rwe2156's profile
rwe2156
2803 posts in 1388 days
#1 posted 10-19-2015 12:28 PM
Sure you’re not talking about cupped? (Cupped is across width, bow is along length).
If its cupped, no way you can do it but there are tricks like ripping board down/jointing and glueing.
If its bowed, you can get away with it, but it depends mainly on the thickness/width + how much bow.
If you force it into place, it will usually bow the whole top.
flamingoezz
5 posts in 864 days
#2 posted 10-19-2015 01:09 PM
it is bowed across the length of the piece. Rough dimensions of the board are 1” x 8.5” x 56”, though I will be cutting the finished length down to 52”. I think the bow was about 1/8” on each side, give or take a 16th.
Total tabletop width will be 29”. Think the other boards would provide enough support to keep the whole top from bowing?
If not, would cutting the board in half and separating those pieces in my tabletop make it less likely to bow?
View mahdee's profile
mahdee
3844 posts in 1675 days
#3 posted 10-19-2015 02:56 PM
Once you put the cross supports in, any bowing should get worked out.
-- earthartandfoods.com
rwe2156
#4 posted 10-20-2015 12:11 PM
Yes – that is not much bow to be worried about.
For some table top applications dowels, biscuits or splining can be used.
View McFly's profile
McFly
273 posts in 934 days
#5 posted 10-20-2015 04:23 PM
If this were me in the shop @ work, I’d add dominos at each end and on both sides of the bowed board, get one side flushed out & glued up and persuade the other end with weights and clamps.
Glue up with west systems 610 epoxy mixed with some wood flour for color and Bob’s your uncle.
