matte lacquer
Forum topic by holsterguy posted 10-18-2015 11:49 AM 911 views 0 times favorited 11 replies Add to Favorites Watch
View holsterguy's profile
holsterguy
36 posts in 1293 days
10-18-2015 11:49 AM
I’m working on a project that requires a dull sheen almost dead flat. I’m using lacquer and I’m having a heck of a time getting it in matte. Does anyone know, can I take a can of satin and carefully pour off some of the clear, without disturbing the flattening stuff at the bottom. Would that then result in a “flatter” finish? Don’t want to use poly. I like spraying lacquer.
11 replies so far
View JoeinGa's profile
JoeinGa
7739 posts in 2241 days
#1 posted 10-18-2015 12:03 PM
Might have to go over it very lightly with 0000 steelwool to dull it down a bit.
View cabmaker's profile
cabmaker
1744 posts in 3043 days
#2 posted 10-18-2015 06:32 PM
You can use a cup gun and thin approx 60\40…......60 percent being the
Lacquer.
You will need to lay up several coats to compensate for the thinning
View Dark_Lightning's profile
Dark_Lightning
3365 posts in 3343 days
#3 posted 10-19-2015 02:25 AM
You can buy spray cans of matte clear lacquer from a metal supply company. I patinate (artificially color) metal projects that I make, and the matte clear covers that finish with absolutely no sheen.
-- Random Orbital Nailer
View Daruc's profile
Daruc
460 posts in 1367 days
#4 posted 10-19-2015 03:47 AM
I would just get some flattening agent from your lacquer dealer.
I use SW and have gotten it from them before.
Pouring off the top may work, but I think it compromises the integrity of the finish. 6 months or a year down the road who knows what the finish might do?
Might be just fine but it’s easier to add a flattening agent and do it right, than to refinish something later.
Daruc
#5 posted 10-19-2015 04:00 AM
You can use a cup gun and thin approx 60 …......60 percent being the
Lacquer.
- cabmaker
How does this change the sheen?
Thinner is just a delivery agent that evaporates off.
Your still putting the same “solids” on, just less of it each coat. Your not changing the composition of the lacquer. Maybe you can teach me, cause I don’t see it.
If anything your just wasting thinner.
View AlanHollar's profile
AlanHollar
10 posts in 1196 days
#6 posted 10-19-2015 06:31 PM
If you add flattening paste, agitate the finish frequently, as the flattening agent may fall out of suspension.
View the_other_ken's profile
the_other_ken
38 posts in 3209 days
#7 posted 10-22-2015 07:46 PM
General finishes makes a matt finish called “Flat Out Flat Self Cross Linking Acrylic Topcoat”. It is supposed to be a “truly flat” finish but I have not tried it.
https://generalfinishes.com/retail-products/water-base-top-coats-sanding-sealers/flat-out-flat-self-cross-linking-acrylic-topcoat
View Yonak's profile
Yonak
986 posts in 1755 days
#8 posted 10-22-2015 08:37 PM
- theotherken
Ken, this sounds very promising and worth trying. I only wish it came in an oil-based.
View hairy's profile
hairy
2783 posts in 3766 days
#9 posted 10-23-2015 12:33 AM
This project used a rattle can spray lacquer. http://lumberjocks.com/projects/81814
It looks like plain wood with no finish.
-- My reality check bounced...
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#10 posted 10-23-2015 12:59 AM
0000 steel wool with wax
Yonak
#11 posted 10-23-2015 01:12 AM
- TheFridge
Actually, I find the fewer the 0s the flatter the finish. Wax also tends to give it some shine. I wonder if a rather coarse rub, with no wax, would attract unwanted visibles, such as dust, over time.
