Need help on how to carve out square corner of a 4x4
Forum topic by gambit posted 10-16-2015 11:50 PM 1014 views 0 times favorited 7 replies Add to Favorites Watch
View gambit's profile
gambit
2 posts in 918 days
10-16-2015 11:50 PM
Total newbie here so not even sure what search terms to try :) Need help cutting out a 2×2 square corner from a 4×4 to get the following shape:
I have access to a table saw, just not sure if I’m oversimplifying it thinking I can set the height to cut halfway through and cut on two adjacent sides. Anything I’m missing?
Thanks for any help you can provide!
7 replies so far
View JoeinGa's profile
JoeinGa
7735 posts in 1971 days
#1 posted 10-16-2015 11:53 PM
You got it.. 2 easy cuts on your tablesaw and it’s done.
And WELCOME to LJs !!
View BurlyBob's profile
BurlyBob
5403 posts in 2230 days
#2 posted 10-17-2015 12:10 AM
Joe is right. Have that very thing several times. Go get ‘er done.” Welcome to the gang.
View ElChe's profile
ElChe
630 posts in 1301 days
#3 posted 10-17-2015 02:01 AM
It seems to me that the only concern is to make sure the 2×2 releases on the side of the blade away from the fence so that it doesn’t get trapped between the blade and the fence?
TopamaxSurvivor
18246 posts in 3640 days
#4 posted 10-17-2015 02:51 AM
It seems to me that the only concern is to make sure the 2×2 releases on the side of the blade away from the fence so that it doesn t get trapped between the blade and the fence?
- ElChe
Great point! If you don’t know about kickback, find out before doing this cut.
View Woodknack's profile
Woodknack
11479 posts in 2344 days
#5 posted 10-17-2015 04:31 AM
The search term is “rabbet”.
gambit
2 posts in 918 days
#6 posted 10-17-2015 04:53 AM
Thank you all for the comments!
View oldnovice's profile
oldnovice
6761 posts in 3332 days
#7 posted 10-17-2015 06:08 AM
If I were to do this I would follow the advice above because these guys have done it before, many times.
But be careful any time using a power tool!
