Long Jointer Adjustment
« back to Hand Tools forum
Forum topic by Gerald Thompson posted 10-16-2015 08:23 PM 919 views 0 times favorited 11 replies Add to Favorites Watch
Gerald Thompson
931 posts in 2228 days
10-16-2015 08:23 PM
Many years ago I came by one of the last Steve Knight’s wooden hand planes. It is 30’’. I must have told him that was what I wanted. I developed a shoulder problem got it fixed then had the other one fixed. I am now ready to have a go at it.
IIRC it is bevel up. I have been on Youtube trying to learn how to adjust the blade depth. I can not get the blade to retract by hitting the butt of the plane. It is just hogging off wood and skittering.
I have just re-sharpened the iron and it cuts hair. So that is out of the way. At present I am too tired and frustrated to try it again today.
How do it get the iron to retract There is only about 1/32” poking out but I think it needs less.
I am still trying to figure out who to blame on me ordering a 30’’ plane. It is a dandy though.
-- Jerry
11 replies so far
View Nicky's profile
Nicky
695 posts in 4085 days
#1 posted 10-16-2015 10:41 PM
It sounds as if the wedge may be to tight. I own two wooden planes, so I’m not an expert. I did build both and had similar problems with both, The wedge may need some fine tuning.
-- Nicky
Gerald Thompson
#2 posted 10-16-2015 11:39 PM
Thanks Nicky. I will have another go at tomorrow. I watched another video that helped me. I think the iron needed to be sharpened too.
-- Jerry
View Don W's profile
Don W
18707 posts in 2560 days
#3 posted 10-17-2015 12:11 PM
What kind of hammer are you using? I find with some wooden planes (I never had a knight) a large wooden mallet works best for retracting the iron.
I also find with some planes its best to just back it up and start over so it never gets to deep.
Gerald Thompson
#4 posted 10-17-2015 12:15 PM
I have been using a small hammer made for plane adjustment. I have a larger wooden mallet I will try. It did occur to me to just start over.
Right now I am facing a lawn that needs mowing. Maybe after a nap I’ll give it a go.
Thanks.
-- Jerry
Don W
#5 posted 10-17-2015 12:22 PM
I’m so thankful my wife hates the way I mow lawn!
View BubbaIBA's profile
BubbaIBA
387 posts in 2369 days
#6 posted 10-17-2015 01:17 PM
Many years ago I came by one of the last Steve Knight s wooden hand planes. It is 30 . I must have told him that was what I wanted. I developed a shoulder problem got it fixed then had the other one fixed. I am now ready to have a go at it. IIRC it is bevel up. I have been on Youtube trying to learn how to adjust the blade depth. I can not get the blade to retract by hitting the butt of the plane. It is just hogging off wood and skittering.
I am still trying to figure out who to blame on me ordering a 30 plane. It is a dandy though.
- Gerald Thompson
Gerald,
You may remember correctly but…..I’ve googled SKP’s and all I’ve found are fairly traditional and bevel down. I would try it bevel down and follow the advise to always advance the iron. If too heavy a cut back the iron out and start over.
ken
Gerald Thompson
#7 posted 10-17-2015 02:47 PM
You are correct Ken. It seemed it would be BU due to the mouth adjustment. There is hardly any space between the fully open mouth and the iron in BD application. I do not know whey the mouth has such far reaching adjustments when only the wide open seems to work.
I used my MF #18 to knock out the high spots on a 6’’ wide pine board. I them proceeded the SK jointer and finished it up. It is not perfectly flat but I know it works.
The shavings are to die for. Thank you so much. I was getting ready to sell it. That will be about 8 years down road when I sell all of my stuff. I will be 80 and I am getting tired of WW.
-- Jerry
View Derek Cohen's profile
Derek Cohen
370 posts in 3961 days
#8 posted 10-18-2015 03:08 PM
Steve only made BD planes. Your plane is 100% likely to be BD. The reason it has little area in front of the mouth is deliberate – it is designed to work best with a small mouth. Steve built in an adjustment section so that the mouth could be kept small.
For setting up wooden planes use a “setting block”. Most recommend a wooden board but my choice is a piece of float glass glued to a board. This will not damage your blade.
Place the plane without blade and wedge on the setting block, and slide in the blade (bevel down!) until it rests on the blade. Press the back of the blade against the back of the bed. Slide in the wedge and press down firmly.
This is a smoother, but the process is the same ..
This set up creates a fine cut. Tap the blade for a deeper cut. Always firm up the wedge after an adjustment.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View paratrooper34's profile
paratrooper34
915 posts in 2945 days
#9 posted 10-18-2015 03:55 PM
It is a very long plane, 30”. You may want to consider placing a strike button on the top forward of the blade. These are very common on lengthy wood bodied planes because the length of the body absorbs the shock from the hammer blow when hit on the heel.
Look at this google search and you will see many of them and how they are placed.
https://www.google.com/search?q=antique+wooden+jointer+plane&es_sm=93&tbm=isch&tbo=u&source=univ&sa=X&ved=0CCUQsARqFQoTCKzBwcevzMgCFcqqHgod3DwK9w&biw=1600&bih=731
-- Mike
Gerald Thompson
#10 posted 10-18-2015 11:10 PM
I have several cherry round door pulls about 3/4’’ in diameter. Could I shorten the tenon, drill a hole and use this for a strike button?
-- Jerry
Derek Cohen
#11 posted 10-19-2015 03:30 AM
You do not need a strike button. It is technique. You need a mallet with a hard end and use a sharp blow.
Regards from Perth
Derek
