Another tool manufacturer that is on my DO NOT BUY list
Forum topic by thelt posted 12-07-2009 11:05 PM 3850 views 0 times favorited 50 replies Add to Favorites Watch
View thelt's profile
thelt
665 posts in 3377 days
12-07-2009 11:05 PM
Delta Machinery/Dewalt tools and any other name they go by. I was told today by the servicenet people that I need to throw my midi lathe away because it is NOT repairable. The run capacitor on the motor burned up and melted and the part has been discontinued. Iasked what I should do about getting a replacement part and the lady told me “the part has been discontinued and there is no replacement. So, throw it away and by a new one”. What kind of crap is that? Had I been a customer service rep, I would have at least tried to be nice. I will not buy another tool from any of their companies. I know it is really going to hurt them. LOL But I can bad mouth the hell out of ‘em and never recommend their products. THEY DON’T CARE, ONCE YOU BUY!
-- When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
50 replies so far
View jack1's profile
jack1
2107 posts in 4024 days
#1 posted 12-07-2009 11:15 PM
That’s unfortunate. I’ve had pretty good luck with most of their stuff I guess. There is no reason why they couldn’t have information as to what could replace the part however. I’d call back again, ask for a supe and crab away! That at least returns some of the aggravation.
View BlankMan's profile
BlankMan
1490 posts in 3350 days
#2 posted 12-07-2009 11:25 PM
That’s DeWalt speaking a.k.a. Black & Decker. I’ve dealt with DeWalt’s ServiceNet support a lot and even before B&D acquired Delta and Porter-Cable they were like that, basically useless. B&D/DeWalt have a totally different mindset as to what Customer Service is. You need to contact Delta directly, that’s what I’ve been doing since this B&D fiasco started, Delta people are more then willing to help and bend over backwards to do it. That’s what helped get Delta to where it is.
-- -Curt, Milwaukee, WI
View Roper's profile
Roper
1389 posts in 3710 days
#3 posted 12-07-2009 11:26 PM
how old is the lathe? and can you just replace the whole motor instead of having to buy a whole new lathe?
-- Roper - Master of sawdust- www.roperwoodturning.com
View knotscott's profile
knotscott
8012 posts in 3373 days
#4 posted 12-07-2009 11:34 PM
You should be able to get another cap from several sources…it only needs to be able to fit, and be close in electrical value.
That service rep’s answer was out of line, but I don’t see her comment as being representative everyone else at Delta/DW/PC/B&D/Devilbiss/Stanley/Oldham. Better to report her than to limit your future tool choices and try to convince others to do the same. I’ll bet if you sent a well worded letter to Delta CS, they’d not only appreciate the insights of this Servicenet employee, but they might even toss a bone your way as compensation….ya never know.
BlankMan
#5 posted 12-07-2009 11:43 PM
It’s not really a good idea to use a capacitor that’s close or one that makes the motor run,. They’re designed to match the windings, using the wrong value can cause the motor to not run efficiently and/or overheat if it’s a run capacitor. If it’s a start capacitor you might be able to get away with it but it could still cause the winding to overheat during the time it’s energized leading to possibly shorter life. And he did say run capacitor.
View DrDirt's profile
DrDirt
4424 posts in 3739 days
#6 posted 12-08-2009 12:18 AM
BlankMan is right – match the capacitor – which should really be no issue, as the motors on these benchtop 1/2 HP machines are definitely nothing “special”. So finding the right capacitance should be like falling out of a boat and worrying about missing the water.
Though if it were an issue I would work to get close – as long as you are close you are unlikely to overheat, but can get shorter life and less efficiency – but the choice between a little inefficiency or junking my lathe – I would sacrifice some efficiency.
View WhittleMeThis's profile
WhittleMeThis
125 posts in 3370 days
#7 posted 12-08-2009 12:36 AM
Talk to a tech rep at Dewalt they should point you in the right direction, service reps don’t know jack about what their company sells, in most cases, they are just reading from a computer screen and ad-libbing when they are stuck.
View MarkwithaK's profile
MarkwithaK
370 posts in 3175 days
#8 posted 12-08-2009 12:38 AM
The rule of thumb with caps is you can go up but you cannot go down as far the microfarad rating is concerned, within reason of course. Typically I try to match the voltage rating but I have used a 440VAC cap to replace one that was rated for 370VAC. I would check w/ your local Grainger.
-- If at first you don't succeed then maybe skydiving isn't for you.
View papadan's profile
papadan
3584 posts in 3365 days
#9 posted 12-08-2009 12:41 AM
Post your lathe model # here and someone with the same lathe # can post the Cap values, You siad it burned up so it may not be legible.
View Brian Havens's profile
Brian Havens
196 posts in 3103 days
#10 posted 12-08-2009 12:42 AM
I had to replace the start cap in my dust collector. (which happens to be a Delta). Is that the same as the ‘run’ capacitor? The guy I bought it from told me that a little larger is OK, but not smaller. (I could not find the exact size.) He also pointed out that capacitors of that size actually have a value “range” even though they may be labeled with a single value. That was last year, and I have had no problems since.
-- Brian Havens, Woodworker http://brianhavens.com
BlankMan
#11 posted 12-08-2009 12:46 AM
Some motors have two capacitors, a start capacitor and a run capacitor so can’t say without knowing the motor mfg & model or looking at it to see if it’s got one hump or two (US made motors).
But humps don’t tell all. My Jet JSG-6 has no humps and it’s a capacitive start/capacitive run motor (has two caps) but they’re hidden.
View GFYS's profile
GFYS
711 posts in 3468 days
#12 posted 12-08-2009 12:52 AM
The service net rep just acted stupidly…you should schedule a beer meeting and work it out over a few cold ones.
TopamaxSurvivor
18269 posts in 3673 days
#13 posted 12-08-2009 02:05 AM
Any motor shop should be able to hand you what you need.
View GEORGE6149's profile
GEORGE6149
32 posts in 3594 days
#14 posted 12-08-2009 03:37 AM
Did you check with a local major electrical supply shop. I needed a capacitor for a compressor.Brought the capacitor and they matched it up with numbers on it. Works great
-- GEORGE
View cstrang's profile
cstrang
1832 posts in 3165 days
#15 posted 12-08-2009 03:48 AM
All on my stationary power tools are Delta and many of my portable tools are DeWalt and Porter Cable, I have never had a good experience with ServiceNet, I needed a set screw for my table saw about a year ago (couldn’t find one with the proper thread pattern anywhere but through Delta) they said it would take about a month to get to me because they do not express ship to Canada… A MONTH!!! I could not use the say with out it, I had to get out my portable Mastercraft table saw and use that for three weeks before the part got to me, suffice to say I was not pleased and will not be buying another Black & Decker product. I am starting to hear more and more bash the Delta name, maybe they will get the message, but unfortunately they most likely will not.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
showing 1 through 15 of 50 replies
