Zero Clearance Insert for Makita 2708?
Forum topic by ChesapeakeBob posted 12-07-2009 09:26 PM 8124 views 0 times favorited 2 replies Add to Favorites Watch
View ChesapeakeBob's profile
366 posts in 3413 days
12-07-2009 09:26 PM
Topic tags/keywords: makita zero clearance insert 2708
Has anyone ever tried amking a zero clearnace insert for a Makita tablesaw? I do not have nearly the table thickness to work with that a Delta or similar saw provide. I have maybe as little as 1/8” to replace the two aluminum inserts (one regular, one dado) that came with the saw many years ago. I use the saw constantly. It has never provided me with any trouble. I have it mounted on a cabinet that I roll around my small basement shop.
Many thanks,
-- Chesapeake Bob, Southern Maryland
2 replies so far
View PurpLev's profile
8534 posts in 3578 days
#1 posted 12-07-2009 09:37 PM
you could make a regular thickness plate (3/8” / 1/2”) and just route the outer edge to whatever the original plates were to fit flush in the opening. not ideal, but better than having the whole insert 1/8” thick.
View dcpugh's profile
1 post in 1888 days
#2 posted 01-14-2013 05:05 PM
I cut one out of red oak for a 2708 someone gave me last year. Routed out the back so it fit the bracket. I don’t have the dado set, so I’ll just use this for now. I may make a plywood one in the future if I get the dado set.
This took a few tries but I got a good fit eventually.
