Ridgid 13" Planer does not feed well
Forum topic by Jim Jakosh posted 12-07-2009 08:23 PM 18887 views 0 times favorited 15 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3341 days
12-07-2009 08:23 PM
I bought a Ridgid 13” planer because I saw a sign maker at a show using one and he did not get any snipe at all on it. I had a Delta benchtop planer that sniped every board. I got this new planer and it ran without much if any snipe and that was a good thing. But then after a month, it stared to stop feeding a board halfway through and I had to pull and push boards through it. They are guaranteed for life, so I took it to the Service Center and they put new feed rollers in it and new plattens. It worked well for a while than began skipping again. I wash off the rubber feed rollers with solvent to make sure they are clean but it still stops too often for my liking.
Has anyone else had this problem?
Do you have a solution short of replacing it?
Thanks, Jim
15 replies so far
View ellen35's profile
ellen35
2739 posts in 3668 days
#1 posted 12-07-2009 08:29 PM
I have the same planer. Whenever I have a problem with feed through, invariably it means that I need to wax the infeed and outfeed tables (and the main table as well). I have minimized snipe by angling the board if possible and lifting it slightly as it comes out of the planer. Check out this website for more good info on Ridgid planers:
http://www.ridgidforum.com/forum/showthread.php?t=21466&highlight=ridgid+planer+snipe
Hope this helps.
Ellen
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4193 days
#2 posted 12-07-2009 08:32 PM
I have an older version of this planer…but with any smaller lunch box style planer you have to make sure of two things..#1 that the machine is not getting gummed up on the feed rollers AND the tables. Many people neglect to keep the in feed and out feed tables clean and waxed. If you are working in sappy woods like cedar or pine then this problem can be worse. I wipe the rollers down with mineral spirits and the tables every once and a while and then give the tables a good coating of dry spray lube. #2….you have to take real small bites…never more than a 1/16”..usually I take less than that. I go in quarter turns, and less if I am trying to avoid tear out. I have been using this planer for over a year and never have had a board stick when feeding. I never have a snipe problem either…if you are having one check the in feed and out feed tables to make sure they are flat…..on my planer they are actually tilted up ever so slightly. The only time I ever see any snipe is if I take too big of a cut.
View PurpLev's profile
PurpLev
8548 posts in 3884 days
#3 posted 12-07-2009 08:49 PM
wax.
someone had posted the very same post in reference to the very same planer a week ago.
View Cory's profile
Cory
760 posts in 3655 days
#4 posted 12-08-2009 05:04 PM
As PurpLev said, I had the same problem about a week ago. I can tell you with authority that waxing the beds makes a HUGE difference. I put on a coat, let it dry then buffed it. I followed it up with a second coat and buffing. Now I can put a workpiece on one side of the planer and with a slight push it will slide off the other side. I also used rubbing alcohol on the feed rollers and made sure there wasn’t anything obstructing them. Basically, a thorough waxing and cleaning completely eliminated the problem for me. I’ve ran quite a few boards through since then (both rock maple and soft pine) up to 6/4 without any trouble.
Hope that helps.
-- The secret to getting ahead is getting started.
View rtb's profile
rtb
1101 posts in 3949 days
#5 posted 12-08-2009 05:24 PM
I have the Rigid 1300 planer and have literary run miles of wood through it. The only time I have wood hang up is either to deep a cut or (and this is the most common)to lite a cut. I do check fro level and keep everything waxed. Also frequent use of the air hose.The dust collection system is quite good, but still not %100.Of course the weight and length of whats being planed can also be a factor. Run a length of say 10ft of Oak and you will probably see snipe.
-- RTB. stray animals are just looking for love
View flyingoak's profile
flyingoak
68 posts in 3344 days
#6 posted 12-12-2009 05:56 AM
I have a Rigid 13 inch planer and i have run hundreds of feet through it. The only problem i have is when i try to take too big a bite. i try only to take betwee 1/32 to 1/16 inch at a pass. slow but few problems
-- where is the duct tape.....
View rgi's profile
rgi
1 post in 1506 days
#7 posted 06-14-2015 05:29 PM
My 13 inch Rigid planner rollers stop rolling for about 1 second every inch. I have watched them do this with no wood running through, so I know it is not related to roller cleaning or waxing. At the same time the blades run steady. The planer was a floor model and has done this since day one. The end result is a snipe every one to two inches.
The only time it has not done it, as frequently was when I increased the cut depth and manually forced the board through. Then it went a couple of inches without pause.
I plane mostly cedar and the blades are in good condition.
MrUnix
7106 posts in 2435 days
#8 posted 06-14-2015 05:35 PM
Open it up and check the feed roller sprockets… sounds like you may be missing a tooth somewhere.
View mandatory66's profile
mandatory66
202 posts in 2366 days
#9 posted 06-14-2015 08:07 PM
Clean & smooth – raise the out feed table until the snipe is gone. I have this planer for 9 years run only oak & have had no problems. Brads advise is sound. !/32 each bite.
View bruc101's profile
bruc101
1261 posts in 3777 days
#10 posted 06-14-2015 08:19 PM
Would the bushings or the rollers maybe have a flat spot on them? I had that to happen to me years ago with a Delta 12 inch.
-- Bruce Free Plans http://plans.sawmillvalley.org
View HerbC's profile
HerbC
1792 posts in 3095 days
#11 posted 06-15-2015 07:42 AM
I had a Rigid R4331 planer. After two years of moderate (and very satisfactory quality result) use, I changed the blades (turned them around to use the other edge). Sortly aftwards I began having feed problems, even though bed was clean and waxed and rollers were clean. The feed rollers would go about 1/2 a revolution then pause then start again, bottom line it became impossible to use. Found the feed drive gearbox was hosed. Had quite a hassle with Rigid because I had NOT submitted the paperwork to register for LSA. Since I did not have the receipt they said tough s**t… I went to the Home Depot store and after a prolonged discussion the young lady who was working returns took the issue to the store manager. Bottom line, they gave me refund on the planer, then sold me a brand new one off the floor (new in sealed box). The new item was elegible for LSA and is now properly registered. The store said they would take the problem unit up with the Rigid people.
My new planer is currently work great.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Harryn's profile
Harryn
76 posts in 2824 days
#12 posted 06-16-2015 04:23 PM
My ridgid had the skipping problem too. it turned out that the roller chain was was stretched to the point that it would skip teeth on the sprocket causing the stop start thing. There is no way to adjust the sprockets to allow for this. you have to replace the chains.
View Underdog's profile
Underdog
1248 posts in 2271 days
#13 posted 06-16-2015 05:19 PM
This doesn’t seem like it would be the problem, but I’ve had trouble with feeding when the knives get dull. There is more resistance to feed when the knives are beating your wood to death instead of cutting.
Sounds more like a mechanical problem with the gearbox, chains or sprockets, or that you need to lubricate your bed, etc…
-- Jim, Georgia, USA
View RJRosa's profile
RJRosa
33 posts in 2384 days
#14 posted 06-16-2015 06:04 PM
I had one of these about 10 years ago with the same issue. I replaced the rollers under warranty and sold it.
Jim Jakosh
#15 posted 06-17-2015 12:44 AM
I must say, Mine is working pretty good now. I changed the knives and wipe the feed roller with alcohol every so often and it is working pretty good. It scares me to hear about all the feed mechanism problems. But they have a lifetime warranty and I had mine in for new rollers and platen right after I bought it at no cost.
cheers, Jim
