Can't remove chuck from PC7515 corded 1/2" drill
« back to Hand Tools forum
Forum topic by roderick posted 10-15-2015 03:37 PM 579 views 0 times favorited 4 replies Add to Favorites Watch
View roderick's profile
roderick
18 posts in 2011 days
10-15-2015 03:37 PM
I have removed the ACME bolt from inside the chuck. Inserted a 1/2” allen wrench into the chuck and hit the allen wrench with the flat side of my Estwing in a ccw direction. Inertia isn’t helping as the armature turns with the chuck. Any suggestions?
Doug in Bedford PA
-- just doug
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1966 days
#1 posted 10-15-2015 03:41 PM
If ccw didn’t work, try cw….. Jerry (in Tucson)
View bigblockyeti's profile
bigblockyeti
5314 posts in 1956 days
#2 posted 10-15-2015 05:09 PM
Most if not all chuck retention screws are left hand thread.
roderick
#3 posted 10-15-2015 05:38 PM
@ Nubsnstubs same problem cw the armature moves before the chuck breaks loose.
@bigblockyeti The ACME ( left hand thread) bolt is already out. It’s the female thread in the chuck that won’t separate from the threaded armature shaft. I may have to remove the front housing and pull the armature out so I can keep it from turning when I swat the allen wrench.
-- just doug
bigblockyeti
#4 posted 10-15-2015 08:01 PM
It usually takes a very hard impact to break a chuck loose from the spindle, the spindle will be right hand thread.
