Rabbet Advise
Forum topic by Joe posted 12-07-2009 06:23 PM 940 views 0 times favorited 7 replies Add to Favorites Watch
View Joe's profile
Joe
185 posts in 3392 days
12-07-2009 06:23 PM
Greetings LJ, I’m starting on a gun cabinet for my father. The door frame calls for a rabbet for the glass. Is it better to cut all the rail and stile rabbets on the table saw before glue up. Or use a router to cut the rabbet after assembled? It’s probably a matter of taste but I am not sure. Thanks….
-- Senior Chief
7 replies so far
View Moron's profile
Moron
5032 posts in 3892 days
#1 posted 12-07-2009 06:43 PM
Its spelt…............Rabbet, not to be confused with the bunny spelt Rabbit
View SnowyRiver's profile
SnowyRiver
51457 posts in 3479 days
#2 posted 12-07-2009 07:22 PM
Joe…I prefer to do the rabbet after assembly using a router. I find it works best to make a couple of passes so it doesnt chip. Also if you assemble the pieces first, especially if you use pocket joinery you will have to be careful that the screws arent near the rabbet area. Then like DaveR said, square up the corners.
Oh, and roman…its spelled, not spelt. :-)
-- Wayne - Plymouth MN
Moron
#3 posted 12-07-2009 07:52 PM
If you run them first, then the two stiles need to have a “stop” rabbet. If you are a novice/intermediate woodworker and using dado blades, this can be dangerous. If you dont stop the rabbet then it leaves open spots at the top and bottom.
As others have stated, using router with a rabbet bit and bearing works for me and despite the fact that you shouldnt do the following…..I run the router back wards as this eliminates “tear out” and the final pass I run the correct direction, then knock thwround corners out with a sharp chisel.
View Joe's profile
Joe
#4 posted 12-07-2009 09:24 PM
Thanks everyone. I think I will assemble the door and square the corners after the router pass.
Note to self…..its rabbet…...LOL
-- Senior Chief
View degoose's profile
degoose
7233 posts in 3353 days
#5 posted 12-07-2009 10:43 PM
Woodwork lessen and a spelling lessen… Oh Lesson, LOL
View Gene Howe's profile
Gene Howe
10479 posts in 3427 days
#6 posted 12-07-2009 11:51 PM
Rebate, mates.
View Gary's profile
Gary
9331 posts in 3431 days
#7 posted 12-07-2009 11:57 PM
lessen? OH POOH
