Sandpaper storage solutions?
Forum topic by lateralus819 posted 10-14-2015 12:04 AM 952 views 0 times favorited 4 replies Add to Favorites Watch
View lateralus819's profile
2241 posts in 1822 days
10-14-2015 12:04 AM
So i made a bulk purchase from Klingspor on behalf of a lot of positive reviews.
10lbs of rolls, 50 sheets of 600 grit, 50 disc and 30 belts. Not bad for less than $100.
Anyways, I was curious to see how some figure a way to store large amounts and keep track of them?
View jmartel's profile (online now)
7741 posts in 2082 days
#1 posted 10-14-2015 12:33 AM
For those rolls, why not make a rack with PVC pipe going horizontally. Then you can store the rolls on the pvc pipe, and just unroll it as you need it. For the sheets/discs, one of those accordion folders with lots of pockets works well and stores small.
Also, festive tablecloth.
View hairy's profile
2626 posts in 3464 days
#2 posted 10-14-2015 12:58 PM
I bought a rolling shelf unit from craigslist. It is ugly, but it’s one stop shopping.
Delbert McClinton, John Prine and Lyle Lovett recorded a song called “Too Much Stuff”. They must have peeked in my basement for inspiration.
-- My reality check bounced...
View terryR's profile
7098 posts in 2240 days
#3 posted 10-14-2015 01:16 PM
Lurking and hoping to find a solution as well!
-- tr ...see one, do one, teach one...
View JayT's profile
5543 posts in 2143 days
#4 posted 10-14-2015 01:24 PM
For the sheets and discs, similar to jmart’s suggestion, one of the guys in our guild uses a portable file box for all his sandpaper. Something like this, though his is metal
Has a file for each size/grit combination to keep them organized, takes up very little space and can easily be moved anywhere in the shop that it is needed. Plus, it keeps most of the sawdust out. I thought it was a great idea and solution to a common problem.
