Company who will cut my design
« back to Joinery forum
Forum topic by Lberg posted 10-13-2015 01:43 AM 873 views 0 times favorited 8 replies Add to Favorites Watch
View Lberg's profile
Lberg
3 posts in 979 days
10-13-2015 01:43 AM
Hi,
Although I haven’t found any sources through Google, I must just be looking in the wrong places. So I came here :-)
What I’m looking for is a company that I can supply a PDF with a pattern on it, and they’ll cut the wood for me. I’ve found companies that will use lasers to cut small pieces of wood, but not larger.
I have some ideas for small pieces to create or add to furniture I’d like to try (personal not to sell), but couldn’t cut the wood myself. Seems like there must be a low cost option for that.
Any guidance is greatly appreciated.
Thanks!
LB
8 replies so far
View Joel J's profile
Joel J
48 posts in 1961 days
#1 posted 10-13-2015 02:12 AM
I don’t know what area of the country you are in, but if in a major city, you should be able to find small to medium size woodworking companies that have CNC routers. If you can’t find them, try sign companies as all the larger ones will have CNC routers…..not as sophisticated as the woodworking variety, but should be able to do the job for you. Also, your files will need to be in vector format, created in either Corel Draw or Adobe Illustrator or another vector based program. JPEGS, etc. are bitmaps and the routing program can’t follow pixels…..only lines as in vector files. Vector files have extensions .eps, .cdr, or .ai. Good luck!
-- Joel, Denver, CO
Lberg
3 posts in 979 days
#2 posted 10-13-2015 02:50 AM
I don t know what area of the country you are in, but if in a major city, you should be able to find small to medium size woodworking companies that have CNC routers. If you can t find them, try sign companies as all the larger ones will have CNC routers…..not as sophisticated as the woodworking variety, but should be able to do the job for you. Also, your files will need to be in vector format, created in either Corel Draw or Adobe Illustrator or another vector based program. JPEGS, etc. are bitmaps and the routing program can t follow pixels…..only lines as in vector files. Vector files have extensions .eps, .cdr, or .ai. Good luck!
- Joel J
Thank you Joe. Regarding the format, I’m a graphic designer so an .eps won’t be a problem. Do you know if there are certain software programs or templates they tend to use, or will just an EPS or PDF be enough?
And it looks like “woodworking” is the optimal keyword when searching for such a company?
View Woodknack's profile (online now)
Woodknack
11769 posts in 2402 days
#3 posted 10-17-2015 04:18 AM
Posting your city might be fruitful.
Sometimes the quickest way is calling around. There is a guy around here with a full size cnc, he loads a 4×8 sheet, zip zip, and he packs up the pieces. He sells a specialized cabinet, very niche, unlikely you’d ever find him by googling but I know he takes on extra work. You’d find him by calling around because he approaches other woodworkers to sell cnc time. So to start I’d call half a dozen or so custom cabinet shops and ask your question, either they will do it or tell you who will.
View BurlyBob's profile
BurlyBob
5547 posts in 2288 days
#4 posted 10-17-2015 05:07 AM
I think JAAune Is involved with CNC. He’s got a topic a page back about oily rags. You might contact him for advice.
View JAAune's profile
JAAune
1802 posts in 2339 days
#5 posted 10-17-2015 06:19 AM
Yes, I do use CNC and lasers but my schedule is booked for at least a couple months with current clients. I’d be happy to answer any questions or provide information though.
View oldnovice's profile
oldnovice
6895 posts in 3390 days
#6 posted 10-17-2015 06:19 AM
Where you are will help identify potential candidates.
Specification such as material, size, tolerances, time frame, number of pieces, cost/pay, would also be helpful.
I have a CNC and I can use PDF files directly!
Lberg
3 posts in 979 days
#7 posted 10-17-2015 07:11 AM
Thanks everyone fore the replies so far. I really appreciate the time.
I’m in the South Bay area of Los Angeles.
oldnovice
#8 posted 10-17-2015 07:41 AM
I am in San Jose!
