Nitrocellulose Lacor repair
Forum topic by snowdog posted 12-06-2009 04:55 PM 1979 views 0 times favorited 5 replies Add to Favorites Watch
View snowdog's profile
snowdog
1164 posts in 3890 days
12-06-2009 04:55 PM
Topic tags/keywords: nitrocellulose lacor repair
I have done a little research but need some guidance on this. My step-son tried to clean his new table top and damaged the finish (about a 6 inch circular spot) and then to make matter worse he scratched another section (8 inch scratch (in the finish only, not the wood).
The finish looks like a mat or satin finish on dark wood. Can you recommend some reading and/or steps to how we can fix it? Should we even attempt to fix this or take it to a pro? I have some skill with brush/rub on rinishes but am not skilled at fixing any finishes other than strip and restart.
Merry Christmas to you all :)
5 replies so far
View John Gray's profile
John Gray
2370 posts in 3793 days
#1 posted 12-06-2009 05:49 PM
Nitrocellulose Lacquer repair:
There’s tons of information here.
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4DMUS_enUS288US289&q=nitrocellulose+lacquer+repair+
snowdog
#2 posted 12-06-2009 08:26 PM
Does it have to be sprayed?
I did that search to start “nitrocellulose lacquer repair” the problem is there is a TON of info.. to much info :)
I’ll keep reading
View Mike_Henderson's profile
Mike_Henderson
18 posts in 3014 days
#3 posted 12-07-2009 03:54 AM
Lacquer is very forgiving because it burns into the old coat. If the ding is not into the wood, just brush on some lacquer – get brushing lacquer if you can. Apply several coats so you get good buildup. Then take a flat sanding block and 800 to 1,000 grit wet or dry sandpaper. Use a little water and sand the bump down to flush with the rest of the finish. Then get some white polishing compound from the auto parts store and use a small damp rag to rub it out. Finish with auto glaze for a better shine. Then wax. You’ll never be able to see the repair.
Lacquer dries very quickly but I like to do the above over several days to a week, just to let the lacquer harden. If you do it too fast, you’ll get a flat surface but a few days later the lacquer will finish drying and you’ll have an indent where your ding was.
Mike
snowdog
#4 posted 12-07-2009 03:41 PM
I have been looking at sprayers for a while but retired this year so I am being careful with my spending (unlike our Gov :)
I have my eye on this:
http://www.woodcraft.com/Product/2020047/18850/Earlex-Spray-Station-Pro-Professional-HVLP-Spraying-Station.aspx
But I am not sure Santa has decided on the sprayer I need yet.
View Moron's profile
Moron
5032 posts in 3801 days
#5 posted 12-07-2009 04:07 PM
Just be aware of “fish eye”, the dreaded and evil result of applying lacquer to wood surfaces that have been exposed to furniture polishes (like pledge) that contain silicone.
