Craftsman 14 in bandsaw what type of blades do I need?
Forum topic by cobrahd1999 posted 10-12-2015 02:55 PM 1881 views 1 time favorited 20 replies Add to Favorites Watch
View cobrahd1999's profile
cobrahd1999
15 posts in 830 days
10-12-2015 02:55 PM
Topic tags/keywords: bandsaw
I have a Craftsman bandsaw Item # 00932607000P Model # BAS350 I know the blades have be 99 3/4” and wondering what teeth per inch I should have on hand I am a newbie to a band saw. So any help with this matter would be very helpful.
thanks for your time.
20 replies so far
View ForestGrl's profile
ForestGrl
450 posts in 956 days
#1 posted 10-13-2015 02:54 AM
The type of blade you need depends on what kind of cutting you expect to do, can you tell us what you’re planning/expecting? TPI is not the only specification you need to choose. There’s also the width of the blade, tooth set, hook angle and thickness of the blade. There’s a good starter guide here, the first 3 pages will help you get started. Information about calculating SFM may not be applicable—it’s for saws that have various speeds available.
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
View junebug's profile
junebug
100 posts in 2274 days
#2 posted 10-13-2015 12:11 PM
I have the same saw. I keep two types of blades on hand. For general use (straight line cuts, large radius, resaw, etc) I use a 1/2” woodslicer.
http://www.highlandwoodworking.com/wood-slicer-resaw-bandsaw-blades.aspx
For tighter curves, I have a 3/16” 4 tpi skip tooth that serves me well.
http://www.highlandwoodworking.com/316-4-tpi-skiptooth-bandsaw-blades.aspx
View jeffswildwood's profile
jeffswildwood
2709 posts in 1847 days
#3 posted 10-13-2015 12:34 PM
Forestgrl, thanks for the tip and the chart. That is just what I needed also.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
cobrahd1999
#4 posted 10-13-2015 04:09 PM
Thanks guys for the info..
cobrahd1999
#5 posted 10-13-2015 07:40 PM
ForestGrl
#6 posted 10-14-2015 02:54 AM
Starrett blades are very well-known and generally admired. I don’t know about Carter, other than their guides, but I would expect their blades to be high quality. I’m behind the times on blade makers, because I have so many blades hanging on the wall, but if you do a search here at Lumberjocks, you might find a thread where everyone pitches their favorite. There may be really good blades at a better price than you pay for the super-well-known names. If I stumble across a good thread, I’ll post the link here.
cobrahd1999
#7 posted 10-14-2015 04:20 PM
ForestGrl thanks…
View Yonak's profile
Yonak
986 posts in 1391 days
#8 posted 10-15-2015 02:16 AM
If you’re looking for a set of Carter guides for this saw let me know. I happen to have an extra set.
ForestGrl
#9 posted 10-15-2015 04:09 AM
If you re looking for a set of Carter guides for this saw let me know. I happen to have an extra set.
- Yonak
delete
Yonak
#10 posted 10-15-2015 07:25 PM
- Yonak
delete
- ForestGrl
Really ? Why ?
ForestGrl
#11 posted 10-16-2015 02:03 AM
- Yonak
delete
- ForestGrl
Really ? Why ?
- Yonak
I asked a question that wasn’t necessary. Looked for a delete option, but LJ has none.
View BurlyBob's profile
BurlyBob
5145 posts in 2135 days
#12 posted 10-16-2015 02:09 AM
I just bought the saw blades that Junebug listed. They are great and that woodslicer blade on my 50- year old Atlas saw does an amazing job. That 3/16” blade does allow me to cut some fairly tight curves. I think both those blades will serve you well.
cobrahd1999
#13 posted 10-20-2015 05:11 PM
ForestGrl should I get a set of Carter guides for my Craftsman Bandsaw Item # 00932607000P Model # BAS350?
thanks for all your help..
ForestGrl
#14 posted 10-20-2015 08:52 PM
Hmmmm, I’m probably not the best person to answer that question. I use Cool Blocks on my Grizzly band saw, they are phenolic laminate that you can push up right next to the blade (Click Here to see them), decidedly low-tech. Whether you should get the Carters may depend on (a) what kinds of cutting you plan to do and (b) how much you feel like spending. I’ve done work with everything from a 1/8” blade to 3/4” blade, detailed curves to resawing with the phenolics and been happy with them. Perhaps there are some Carter users out there who can tell us what they can help with, problems they solve? Have to admit, I don’t have hundreds of hours of band saw time under my belt, but have done a variety of cutting.
View bearkatwood's profile
bearkatwood
1446 posts in 881 days
#15 posted 10-20-2015 08:58 PM
I used a saw very similar to that one for years. I like to use a 3/8” blade with a 3 or 4 tpi hook blade. It seems to be a good all around blade for cutting out curved parts as well as re-sawing.
-- Brian Noel
