What is an Inexpensive Fastening System for Picture Frames for Small Shops?
Forum topic by helluvawreck posted 10-11-2015 06:17 PM 1544 views 0 times favorited 34 replies Add to Favorites Watch
View helluvawreck's profile
helluvawreck
31071 posts in 2864 days
10-11-2015 06:17 PM
Topic tags/keywords: fastening system for picture frames picture frames
What is an inexpensive fastening system for picture frames for small shops? Thanks
helluvawreck aka Charles
34 replies so far
View Dutchy's profile
Dutchy
2921 posts in 2166 days
#1 posted 10-11-2015 06:25 PM
helluvawreck
#2 posted 10-11-2015 06:34 PM
Dutchy, thanks for the comment. This is for small production in a small shop. A nail may not be fast enough. I don’t know if there’s anything that is affordable. I hope there might be. I can build a decent clamp system with air cylinders but what about the fastening of the frames?
Thanks,
View madts's profile
madts
1862 posts in 2337 days
#3 posted 10-11-2015 06:46 PM
1/2 a nail if things are tight!
Madts.
-- Thor and Odin are still the greatest of Gods.
View Don Butler's profile
Don Butler
1092 posts in 3393 days
#4 posted 10-11-2015 06:47 PM
Most frames shops use brad nailers, but I have known people to use CA with accelerator, some use just wood glue. That isn’t very fast.
I personally like a brad nailer with Titebond III.
Don
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View Joe Lyddon's profile
Joe Lyddon
10097 posts in 4050 days
#5 posted 10-11-2015 06:48 PM
Nails/Pins shot with a FAST air gun? :)
View drewpy's profile
drewpy
805 posts in 1355 days
#6 posted 10-11-2015 06:48 PM
brad nailer
-- Drew -- "The greatest wealth is health".
helluvawreck
#7 posted 10-11-2015 06:54 PM
With a brad gun or hammer? I assume that you mean in the edge thru first piece into adjacent piece with brad or nails parallel to face and perpendicular to the mitered joint line. I have made some frames like this but not in quantity. It might work if I had the right clamp setup.
Thanks, Madts.
View MrUnix's profile
MrUnix
6710 posts in 2197 days
#8 posted 10-11-2015 06:57 PM
Are these frames that are being made on demand, or something that you can glue and put aside to dry for a few hours? When I’m doing multiple frames (and I only have 1 frame clamp), I’ll glue and clamp the frame, then shoot one or two staples across each joint (after waiting a couple minutes for the glue to setup) so I can take it out of the clamp and move on the the next one. The staples get removed after it’s all dry. If glue isn’t an option, corner v-nail systems work great… and range anywhere from a fairly cheap hand held punch tool to pretty fancy clamp/press systems that can get expensive quick.
Don Butler
#9 posted 10-11-2015 06:58 PM
I use an electric brad nailer.
Then brads go in throughthe corner into the adjacent member. Two in each corner would allow you to keep working until the glue cures.
Don
View GaryL's profile
GaryL
1099 posts in 2828 days
#10 posted 10-11-2015 07:04 PM
http://www.amazon.com/PICTURE-V-NAILER-JOINING-Diameter-Picture/dp/B00NMM4HIY
This is something along the lines of what I’ve been wanting to get. Is this what your looking for? Shoot and deliver.
There are also press versions of the v nailer that push the v nail in rather than shooting it. I believe that is what most frame shops use.
I have a corrugated nailer but it’s a bit too aggressive for picture frames.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
Joe Lyddon
#11 posted 10-11-2015 07:06 PM
I’ve seen a Plastic glue on TV that’s supposed to be SUPER STRONG… one dab… treat with UV light (push button), & it’s cured almost instantly…
helluvawreck
#12 posted 10-11-2015 07:07 PM
25 piece’s at a time and all the same size. They would just need to be made reasonably efficient or it wouldn’t be practical. They would be for a craft product, laser engraved signs for the internet. The item framed would be 1/16 – 1/8 laser engraved plywood.
View DocSavage45's profile
DocSavage45
8554 posts in 2840 days
#13 posted 10-11-2015 07:08 PM
Charles,
If you are working quantities of frames might set up jigs that will hold the frames? Next is speed vs. Quality? a spliene might not be fast as a nailer or Pneumatic stapler, but you can emphasize quality of construction in your sales pitch?
Harbor freight also sells banding straps, which might be efficient as well if you are gluing?
Them’s my two quarters worth but now worth two cents? LOL!
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Sodabowski's profile
Sodabowski
2374 posts in 2831 days
#14 posted 10-11-2015 07:11 PM
http://www.leevalley.com/en/wood/page.aspx?p=52289&cat=1,43293
I saw it as a pneumatic version somewhere if I remember well, but can’t seem to find it back
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
helluvawreck
#15 posted 10-11-2015 07:18 PM
I would build a pneumatic frame clamp to hold them during glueup and assembly. However, they would have to be removable from the clamp immediately so the fastener would have to be strong enough to keep them secure while drying. I have thought about the spline idea but I don’t think the price would allow it. If I had the clamp next to my engraver I might could allow them to sit in the clamp for 3-5 minutes without to much inefficiency in order to secure them better before removing them for the glue to dry.
showing 1 through 15 of 34 replies
