bookmatch help
Forum topic by Richard posted 12-05-2009 06:01 PM 1154 views 0 times favorited 5 replies Add to Favorites Watch
View Richard's profile
Richard
113 posts in 3535 days
12-05-2009 06:01 PM
Topic tags/keywords: book match glue up walnut
Yesterday I tried to glue a bookmatch set of figured walnut. After the tape came off and glue dried i can see an ugly line down the middle. Is there a way to fix this or do I need to start over? The wood is 5/8ths thick. I used painters tape to prevent glue squeeze out from making a mess but I think it is a glue line that is showing. Any advise would be much appreciated. Thanks
5 replies so far
View Sacadelic's profile
Sacadelic
43 posts in 3415 days
#1 posted 12-05-2009 08:18 PM
Scrape it off with a card scraper…
-- Sac
View Chris 's profile
Chris
1879 posts in 4111 days
#2 posted 12-05-2009 08:27 PM
Pretty much scrape then sand or plane a little…. A lot of folks will advise you that when you get the glue up clamped let it set for an hour then comeback and scrape of the semi congealed glue. I have tried this after ending up with a lot of hard glue to scrape and it worked wonderfully.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View John Gray's profile
John Gray
2370 posts in 4005 days
#3 posted 12-05-2009 08:34 PM
My 2 cents: If you end up having to start over saw straight down the glue line and you should then have a perfect splice.
View Julian's profile
Julian
880 posts in 3645 days
#4 posted 12-05-2009 09:16 PM
Was the seam perfectly straight and square? What type of clamps did you use and how many? Why did you tape the seam in the first place? Just scrape the glue off after about 15-20 minutes after glue up if you are worried about the glue getting on the face.
-- Julian, Park Forest, IL
Richard
#5 posted 12-05-2009 11:03 PM
Thanks for the help. A little planing and sanding did the trick. I was nervous about the planing because I have a tendency to gouge, but all came out well. The seem is only noticeable in a small 2 inch area, probably because I know the seem is there. I will work on it further and hope it does not jump out on me when I apply a finish. Thanks again.
