Impregnating with resin
Forum topic by DHaden posted 10-10-2015 08:57 PM 774 views 0 times favorited 6 replies Add to Favorites Watch
View DHaden's profile
DHaden
77 posts in 2621 days
10-10-2015 08:57 PM
I am looking into making my own wood lacrosse shaft(just like from my playing days). The question is how do I get resin, poly, or what ever I decide is best impregnated into the entire shaft, not just the surface.
-- Measure once, cut twice.
View pjones46's profile
pjones46
1001 posts in 2605 days
#1 posted 10-18-2015 01:14 AM
Dip it just like they do some pens, bird calls and paddles, then hang to dry/cure.
-- Respectfully, Paul
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2960 days
#2 posted 10-18-2015 01:28 AM
This: Cactus Juice
Though you are going to need a bit setup to handle the length of a lacrosse stick.
Greg
View Pezking7p's profile
Pezking7p
3217 posts in 1613 days
#3 posted 10-18-2015 02:30 AM
I was just thinking about this today. You would need a resin with a fairly high cross link temperature, or a special apparatus to pressurize the resin. I would think a looong slow (24 hr?) epoxy would work well. I bet you can find some polyester resins on the web, too.
-- -Dan
DHaden
#4 posted 10-18-2015 03:40 AM
I think I am going to have to use some type of vacuum., maybe PVC tube. just need to figure out the vacuum pump.
pjones46
#5 posted 10-18-2015 04:29 AM
This is somewhat like what you are trying to do on a small scale:
http://www.aescustomknives.com/docs/tutorial11.htm
You will have to create the vacuum from within the wood shaft along its length and that’s going to be the key.
In other words the shaft has to be hollow to pull the vacuum and insure total Impregnation.
Here is one way to make a vac pump: http://www.dream-models.com/VacuumPump
Let us know what works out, good luck.
View MrUnix's profile
MrUnix
6574 posts in 2161 days
#6 posted 10-18-2015 04:55 AM
Impregnating it with anything isn’t required, is it?
How it's made - Lacrosse Sticks
(Sitting here with an aluminium Lacrosse stick next to my desk :)
