To sand to.....
Forum topic by kolwdwrkr posted 12-05-2009 08:29 AM 807 views 0 times favorited 4 replies Add to Favorites Watch
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3584 days
12-05-2009 08:29 AM
Topic tags/keywords: question
I am turning a vase and am quite frankly an amatuer at turning. My tools seem to suck, but it’s probably more my ability then the tools. I seem to leave a lot of damage and checking on the inside of the turning, and have to force my way in. This is sketchy because then it grabs the tool and smacks me in the side of the head. LOL. Anyhow, I’ve gotten to a certain point and have 2 questions. How smooth do I need to get the inside if you don’t ever see it or can’t even touch it? Second, if you do smooth it good how do I get in there. I try to scrape it and it leaves lines. I suppose I can make some sort of tool to hold some sand paper on and get down in there. What do you turners out there think?
View tamboti's profile
tamboti
207 posts in 3136 days
#1 posted 12-05-2009 02:05 PM
Hi If the opening is so small you can only get your finger in YOU are not a amature but an acomplished turner.
1 Fix apiece of sand paper to the tip of a glove finger that fits in the opening and sand at a low speed+-350-500rpm. Use velcro ( hook and loop )
2 If you can not touch it or see inside leave as it came of tool and paint black if you can.
3 If any body asks spin a story
I leave unsanded if not seen or cannot be touched.
Regards Roger in SA
-- Africa is not for sissies
kolwdwrkr
#2 posted 12-05-2009 06:00 PM
Thanks Roger. I’ll try the glove idea and see how that works. I think I can get two fingers down in there. One other problem is that it’s sculpted. I had to do the sculpting before I hollowed it because otherwise it would have been to fragile to do chisel work. So it’s no longer round, and the mouth has a cut out that could potentially catch and rip off my finger. But I’ll give it a whorl and see what happens. If it doesn’t seem to work out I may paint it black as suggested. Take care and thanks for the help
Douglas Bordner
4024 posts in 4058 days
#3 posted 12-05-2009 06:09 PM
How about using a piece of folded sandpaper held with a curved hemostat – medical clamp?
23914 posts in 3845 days
#4 posted 12-05-2009 09:56 PM
Keith. Watch those fingers in small openings. Not a pretty sight to see a twisted off finger. Above advice good but take it carefully. Try a narrow chisel to go straight in rather than come from the side.
There are special hollowing tools for inside work like the “Rolly Munroe hollowing tool”. Good luck.
