Another "Power" question: This time about routers
Forum topic by wmgworks posted 10-10-2015 12:00 AM 1130 views 0 times favorited 24 replies Add to Favorites Watch
View wmgworks's profile
wmgworks
194 posts in 1106 days
10-10-2015 12:00 AM
There is a CL ad for a 1 HP router with some guides and a dovetail jig for $40. When I look up reviews on the router I find none at that hp level. everything is 1 3/4 and up. I don’t own a router and want to get one. Will that one work for weekend warrior type stuff?
-- Butchering wood since 2015
24 replies so far
View Clarkie's profile
Clarkie
455 posts in 1962 days
#1 posted 10-10-2015 01:54 AM
That router will work, but it will work to make you want a more powerful one. Usually the 1 hp only has a 1/4” collet system and while it will cut, you’ll never be satisfied until you get your hands on a 2 or 3 1/4hp with a 1/2” collet system. If you just want to get familiar with using one then for 40.00 you can’t really go wrong. Have fun, make some dust.
View ForestGrl's profile
ForestGrl
450 posts in 1207 days
#2 posted 10-10-2015 11:49 PM
There is a CL ad for a 1 HP router with some guides and a dovetail jig for $40. When I look up reviews on the router I find none at that hp level. everything is 1 3/4 and up. I don t own a router and want to get one. Will that one work for weekend warrior type stuff?
- wmgworks
Ditto to what Clarkie said—especially stay away from 1/4” collets, you’ll just get frustrated with it (and if you over-match it with a project, it could be unsafe). Personally, I like a moderate-sized router for hand work (PC690, for instance), and then a big horse in a router table (e.g., Freud 3+HP oldie). You might check eBay for the Porter-Cable 690, which is an older model, see if there’s a good one that includes the plunge base. Then you’d be pretty well set for most projects. Think twice about buying a cheap or junkie router—I bought 2 or 3 before I got smart and waited for a good one to hit CL. Lost some $$ on the cr*p that could have been spent for a decent router bit or two (or three).
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
View Richard H's profile
Richard H
489 posts in 1801 days
#3 posted 10-11-2015 12:07 AM
I have a Dewalt 1 1/4 HP compact router that is absolutely wonderful to use for light duty work. It’s my goto router for things like rounding over table edges or even small mortises. It’s light weight and LED light makes it very easy to use. Now I also have a 2 1/2 HP router that I use with larger bits and a big router that spends it life in a table but for a lot of things those small routers have a lot of advantages.
Does the router have both a fixed and plunge base? A 1 HP router with a fixed base only is probably more in line with a trimmer than a full featured router. Also is it variable speed or fixed?
wmgworks
#4 posted 10-11-2015 12:14 AM
- ForestGrl
Which is why I posed the question first :) I don’t want to buy more than I need, but I don’t want to spend money on useless stuff either
Thanks!
ForestGrl
#5 posted 10-11-2015 03:37 AM
Which is why I posed the question first :) I don t want to buy more than I need, but I don t want to spend money on useless stuff either
Thanks!
- wmgworks
Another heads-up from one who’s been there: routers can almost be like clamps “Can’t have too many.” ;-)
117203 posts in 3698 days
#6 posted 10-11-2015 03:58 AM
I agree with Forest girl you can’t have too many routers(having 38 myself).As a handheld router goes a 1 1/2 hp works fine for must operations. I also agree that 1/2” router collets and bits give you the best performance. Just likemost tools the low-end product lines don’t last as long or perform as well.
View Glen Peterson's profile
Glen Peterson
556 posts in 3177 days
#7 posted 10-11-2015 04:12 AM
I agree with Jim and FG. I think I have 6 routers. The first was a craftsman. If you lived nearby I’d give it to you. The one in the ad is likely sufficient. But you will buy others with more power, larger collet, that plunge, to set under a table, or even a handy trim router.
Cheers
-- Glen
Glen Peterson
#8 posted 10-11-2015 04:14 AM
Cheers
-- Glen
View dhazelton's profile
dhazelton
2789 posts in 2417 days
#9 posted 10-11-2015 01:04 PM
You never tell us the brand of the router.
I have a Craftsman that only takes 1/4 inch collet bits and for simple round over or edge bead it’s just fine. I also bought a Bosch Colt last year and it excels at that kind of work without the heft of the Craftsman and I prefer using that. Before you go out and buy a massive router try a small one first. Big CAN be too big.
wmgworks
#10 posted 10-11-2015 02:23 PM
- Richard H
Thanks Richard. It’s a fixed base. And fixed speed.
wmgworks
#11 posted 10-11-2015 02:29 PM
I have a Craftsman that only takes 1/4 inch collet bits and for simple round over or edge bead it s just fine. I also bought a Bosch Colt last year and it excels at that kind of work without the heft of the Craftsman and I prefer using that. Before you go out and buy a massive router try a small one first. Big CAN be too big.
- dhazelton
Here a link to the ad. It’s a Craftsman. It also comes with some templates and a dovetail jig. Thought maybe if the router wasn’t worth the money everything else might be
ForestGrl
#12 posted 10-11-2015 09:49 PM
Here a link to the ad. It s a Craftsman. It also comes with some templates and a dovetail jig. Thought maybe if the router wasn t worth the money everything else might be
- wmgworks
Here's a good link (yours had a couple extra letters in the url). Craftsman dovetail jigs are pretty inexpensive, especially one that short (narrow). I would not want to run dovetails with that router. IMHO, not a direction you want to head. Hang tight for one of the better brands, so you can build on it. Don’t know if you can afford new, but with the holidays coming up, there will be some good sales!
wmgworks
#13 posted 10-12-2015 01:30 AM
I agree with Jim and FG. I think I have 6 routers. The first was a craftsman. If you lived nearby I d give it to you. The one in the ad is likely sufficient. But you will buy others with more power, larger collet, that plunge, to set under a table, or even a handy trim router.
Cheers
- Glen Peterson
Out of curiosity – why so many routers? I only saw needing 3. ONe mounted in a table, one fixed and one plunge. Why so many? (sorry – little new to some of this)
ForestGrl
#14 posted 10-12-2015 02:33 AM
Cheers
- Glen Peterson
- wmgworks
The three you list are plenty to get your work done. If one happens to “accidently” buy an extra router or two (including a trim router), then it’s a bit easier to do multi-step procedures, keeping your setting on each router as you move from one piece to another, even one day to the next. Truth be told, you probably could get by with two: 1 fixed-base, and a plunge that would work either in-hand or in a table. A hassle, but doable.
View TheDane's profile
TheDane
5516 posts in 3783 days
#15 posted 10-12-2015 01:41 PM
If you are using routers to make your living, time is money. I have a friend who is a pro (he builds high-end conference tables, etc.) ... he has a floor-to-ceiling bookshelf in his shop that is loaded with routers. Each has a specific bit, setup to cut a specific profile. Instead of tinkering around changing and calibrating bits, he just grabs the appropriate router and gets on with it.
