| Forum topic by LouJC | posted 1265 days ago | 2401 views | 0 times favorited | 20 replies | ![]() |
1265 days ago |
Topic tags/keywords: table saws motors wiring motors I just recieved a Dayton 6K727, 1 HP, motor to power my vintage Craftsman table saw, Hay, it was free I can’t complain. Any way, it turns the wrong way, does anyone know WHERE I can find a diagram to rewire it to run the other way. All the info. I can find says it can be done ( Rotation—CW / CCW in all the Tech. Specs. ) -- Lou - Maine |
20 replies so far
#1 posted 1265 days ago |
isn’t there a diagram inside the cover ? there usually is . -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#2 posted 1265 days ago |
How many wires are there coming out of the motor? What wires are tied together? -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
#3 posted 1265 days ago |
T8 and T4 are tied togeather -- Lou - Maine |
#4 posted 1265 days ago |
OH, I ment to tell you before : -- Lou - Maine |
#5 posted 1265 days ago |
This turned out to be interesting. I did a quick Google to see if I could find anything and although I didn’t find the wiring for the motor I found that it appears Dayton is owned by W. W. Grainger i.e Grainger. I didn’t know that. Usually you can find the motor manufacturers web site and sometimes find the wiring but all leads on anything Dayton lead to www. grainger.com. And there it turns out this motor is discontinued and since it also appears from what I read Grainger is the only retailer for Dayton stuff so you might have to contact Grainger for the wiring diagram. If you do I’d like to know how that works out, I’m curious to know what support there is for discontinued Dayton/Grainger motors from Grainger. That sure don’t sound right though because you can find Dayton motors for sale all over. Unless those are used. Don’t quote me on this, it’s just what I read. -- -Curt, Milwaukee, WI |
#6 posted 1265 days ago |
Ya Blank, Thats why I cam here to ask, everything was a dead end at Granger, I guess I will have to call them on Monday. I’ll let you know what I find out. -- Lou - Maine |
#7 posted 1265 days ago |
Ok maybe it is true found this: http://www.grainger.com/Grainger/static/tf_m_daytonmotors.html Dayton® Motors… Exclusively from Grainger. So maybe you’re going to have to contact them. There is surprising very little information on this motor on the web. One thing I did pick up on, it’s a 1725 RPM motor, is that the right speed for a table saw? The blades usually spin faster, is there a big pulley on the motor and a smaller one on the arbor to increase the speed? Just wondering. -- -Curt, Milwaukee, WI |
#8 posted 1265 days ago |
Yes, the motor I took off was a 1750 RPM, so I will have to rework the pulleys, also this motor has a 5/8 shaft, the old one had a 1/2” shaft. I will have to get the book out, my formulas aint THAT good any more. -- Lou - Maine |
#9 posted 1265 days ago |
I think We Got It, I carefuly cleaned the diagram on the motor and the process of elimination, put a combination of wires togeather and it runs even in the right direction, BUT I’m not shure if its set for 110v or 220v, but it sounds good. I will get it tested tomorrow to find out if it is 110 or 220 -- Lou - Maine |
#10 posted 1265 days ago |
I think We Got It, I carefuly cleaned the diagram on the motor and the process of elimination, put a combination of wires togeather and it runs even in the right direction, BUT I’m not shure if its set for 110v or 220v, but it sounds good. -- Lou - Maine |
#11 posted 1265 days ago |
The most typical arrangement for reversible single phase motors is to switch the connection of leads 5 & 8. If the leads aren’t numbered it is often the black and red. |
#12 posted 1265 days ago |
dfarr – I think that is exactly what we ended up with. -- Lou - Maine |
#13 posted 1264 days ago |
Usually its a swap with #5 and #8 to reverse rotaton -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
#14 posted 1264 days ago |
You got me thinking with all the T8, P1, T5, etc. so it dawned on me this might be a NEMA or some standard marking and wiring. So I pulled out the schematic for the 1-1/2HP Leeson motor on my cyclone and compared it with your info, and yep I think it is. So, for 110V CCW wiring: For 110V CW wiring: For 220V CCW wiring: For 220V CW wiring: -- -Curt, Milwaukee, WI |
#15 posted 1264 days ago |
Hey Lou, if it was a 1750 RPM motor and this one a 1725 RPM motor I wouldn’t bother redoing the pulleys just get the same size for the shaft. You may not even be able to pick one up in the incremental size you would need to do that. If they were 2:1 to get up to 3500 RPM you’re not going to notice 3450 RPM. And 1725/1750 RPM is due to the slip that is necessary to make the motor spin from the theoretical max of 1800 RPM (for that motor) and 1725/1750 RPM motors are pretty much used interchangeably. -- -Curt, Milwaukee, WI |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
