I built a lathe and bought some turning tools but in the set I have the fluted gouges are all flat ended. And every time I see a wood turner using his tools they are using a flared back fluted gouge. Is this something I need to do too one of my gouges myself or do some come that way. I have 3 in varying widths.
Thank you in advance for your help
You really need to post pictures of tool you have before can answer your question sounds like talking about continental gouges and or skews & scrapers.
A lot of spindle turning sets have tools like these.
Only difference betwwen the two sets is number of gouges and HF throws in two continental or german roughing gosges and Packard has one U shape roughing gouge. Quality maybe another issue.
Most roughing gouges have flat ends. They are so many ways to grind a gouge that it really doesn't matter, grind them the way you like them. You need to figure out whether you have spindle gouges or bowl gouges and then find a grind you like for each.
Here is a pic of the 3 gouges that I have the largest 1 1/4 is a roughing gouge I guess and the other 2 don't look to have a deep enough flute as the ones I have seen that are cut back on the sides but looks can be deceiving. I think I will cut back the small one to look like a fingernail because I don't know for sure if they are spindle or bowl gouges. Also got a pic of my lathe I made
I would say the largest is a spindle roughing gouge and the two smaller spindle gouges. Most of the time the roughing gouge is straight and spindle gouges are swept back somewhat. Here is a link to Thompson tools, take a look at the spindle gouges for an average sweepback. http://www.thompsonlathetools.com/tooltype.asp?TYPE=S
To show why they are different here are two videos by John Lucas. You will note the different uses of the two gouge styles.
Well looks like you have a killer lathe and tools, make sure wear face shield before proceeding to assault that piece of wood.
Here is a picture of finger nail ground Sorby continental gouge, bevel angle approximately 45 degrees. Shape of flute may differ somewhat from what you have but basically same tool & use!
All the turners I know grind their own profile on what they call detail gouges. In your case it would be the two smaller gouges.
You can purchase a Wolverine grinding set for your slow speed grinder that will help you put the profile on them. Here is a link the Wolverine clone I purchased (scroll down the page till you get to item 7393).
Always bear in mind that the largest of the tools, the roughing gouge, is more properly called a spindle roughing gouge, meant to be used for spindle work only, and needing the tool rest kept pretty close to the work. Both the geometry of the tool and the thinness of the tang where it enters the handle make this tool unsafe, and unsatisfying as a bowl turning tool
I don't know what brand they are there is no markings at all, but I bought them at a garage sale a set of 8 for 5 dollars and figured I would have to temper them. So far there is no need that piece of wood on the lathe was an 8×8x9 square cedar block and I rounded it with the roughing gouge to a 7in cylinder and it kept an edge.
IF they are HSS they DO NOT require tempering. Please find a local woodturning club/individual to determine what type steel the tools are - or - if there is a Woodcraft Store in your vicinity, they can help.
yes thats the grind. I started doing that on the smallest one and I probably will do it to the middle one also.
Also with the spark pattern and the fact that the ones I have used kept a good edge I'm sure they are HSS.
Now that my wood is round and I increase the speed I need to make a live center on my tailstock.
I like making the stuff to make stuff,more than I like making stuff.
This is known as the Elsworth grind. David Elsworth created this grind and it has become probably the most used in the biz. Tormek makes a jig that will produce this grind repeatedly perfect. I don't remember the part number but I use it and it works perfectly every time.
Which came first, "Irish Grind form Liam O'Neil & Michael O'Donnell, or Ellsworth Grind"?
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
