Jointer Knives?
Forum topic by Scotty Stepp posted 12-04-2009 05:23 PM 5965 views 0 times favorited 13 replies Add to Favorites Watch
View Scotty Stepp's profile
Scotty Stepp
25 posts in 3800 days
12-04-2009 05:23 PM
I need to replace my Delta JT360 jointer knives. 6 1/8 inch long.
Any suggestions?
Thanks!
13 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3438 days
#1 posted 12-04-2009 05:26 PM
http://www.holbren.com/jointer-planer-knives/
Try these guys, they are pretty good.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3524 days
#2 posted 12-04-2009 05:31 PM
Freud makes all sizes of jointer knives. I am sure they have the right size. If you know the actual size of the knives. Just measure the thickness, width and length of your old ones.
Or you can do this——http://www.toolpartsdirect.com/cgi-bin/parttools.cgi/37-658
-- http://shepherdtoolandsupply.com/
View Straightpiped's profile
Straightpiped
89 posts in 3729 days
#3 posted 12-04-2009 06:37 PM
That toolpartsdirect seems expensive. I have had good luck with Grizzly knives. My current set is CMT and I have been unhappy with them, JMO.
-- T. Nelson
Kent Shepherd
#4 posted 12-04-2009 07:20 PM
Staightpiped, You may be right. I didn’t bother to check prices. I just did a quick search for that jointer, and that’s the first one I found. CMT is also good. Probably Grizzly too. I guess maybe we all made the point that there are a lot of options, they don’t need to be Delta knives.
Scotty, If you have a local dealer, you might check there first. Online is a great alternative if you don’t.
View MedicKen's profile
MedicKen
1615 posts in 3700 days
#5 posted 12-04-2009 09:47 PM
http://www.amanatool.com/
View karday1286's profile
karday1286
5 posts in 1779 days
#6 posted 04-05-2014 12:03 AM
Kent: Maybe you can help me. I inherited a JT 360 Jointer (Delta) and it is new but was a store model so no knives nor the bars that hold them in. I bought them from Delta. But the bolts that secure the bars (12 ea) were no longer available Delta said they thought they were 1/4”x28×3/8” right hand hex hear bolts. Any way you can confirm that? Grizzly has similar jointer and they use 1/4”x28×9/32”size but they call them GIB screws.
View OldWrangler's profile
OldWrangler
731 posts in 1832 days
#7 posted 04-05-2014 12:42 AM
Go to eReplacementParts.com and put in your model #. They will have a part diagram and sometimes the parts too. If not try Blades.com, they have about all kinds of blades.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
OldWrangler
#8 posted 04-05-2014 12:48 AM
I went ahead and checked with eReplacementParts.com and they do carry the jointer knives. They are on back order until May and the set of 3 is a little over $100.
MrUnix
7106 posts in 2437 days
#9 posted 04-05-2014 12:51 AM
Those blades are listed as 6” x 5/8” x 3/32.. you should be able to use the Freud C350 knives which are 6” x 5/8” x 1/8”. Amazon has them for about $25 for a set of 3.
karday1286
#10 posted 04-05-2014 12:57 AM
Thanks, I tried them and the knife screws are discontinued. Blades.com has no to do about jointers so maybe its another site??
karday1286
#11 posted 04-05-2014 01:10 AM
I have the blades. I am trying to get the knife bolts which are no longer sold.
MrUnix
#12 posted 04-05-2014 01:39 AM
My post was regarding the original question karday… but for your missing bolts – ereplacements show them to be 1/4”x3/8”x28tpi right hand grade 8 bolts.. pretty easy to verify (take one that size/tpi and see if it fits), and you can probably pick 12 of them up at Ace or any other decent hardware store for a couple bucks.
TheWoodenOyster
1317 posts in 2173 days
#13 posted 04-05-2014 11:28 AM
www.americannationalknife.com
-- The Wood Is Your Oyster
