Another question: Router Guide bushing
Forum topic by EdsCustomWoodCrafts posted 10-08-2015 05:57 PM 628 views 0 times favorited 9 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
740 posts in 1213 days
10-08-2015 05:57 PM
I’m really out of my element with this type of routing so I gave a question..
I want to cut box joints 1/2” wide x 3/4” high.. I’m using a 1/2” diameter straight bit and the bit has a cutting depth of 1”.
So my question is what size bushing do I need to keep all my box joints uniform in height?
Sorry to be a pain this week but I’m trying to break my comfort zone and it’s a little hard!!!!
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
9 replies so far
View Ocelot's profile
Ocelot
1862 posts in 2508 days
#1 posted 10-08-2015 06:09 PM
So the fingers are 1/2”? If it’s 3/4” high you only have one finger on one side and 2 half fingers on the other. Probably I’m not understanding what you are doing. Could you explain more? A photo of a hand-drawn sketch would help.
What template are you using? Are you using a dovetail jig?
-Paul
4820 posts in 2363 days
#2 posted 10-08-2015 06:10 PM
I’m puzzled by why you would need a bushing at all. Is the design of your jig such that you have to use one?
EdsCustomWoodCrafts
#3 posted 10-08-2015 06:17 PM
So the fingers are 1/2”? If it s 3/4” high you only have one finger on one side and 2 half fingers on the other. Probably I m not understanding what you are doing. Could you explain more? A photo of a hand-drawn sketch would help.
-Paul
- Ocelot
I’m using a box joint jig with 1/2” key on my router table..
To be honest I’m not in a project yet as i want to get my setup squared away .. I haven’t decided what project I’ll be doing .. Probably a box of some kind..
I was thinking that a bushing would take out all the measuring that I would need to do to achieve uniformed slots and fingers
EdsCustomWoodCrafts
#4 posted 10-08-2015 06:20 PM
I m puzzled by why you would need a bushing at all. Is the design of your jig such that you have to use one?
- Fred Hargis
My router table is homemade and it’s extremely difficult in measuring depth cuts with the router I have.. I thought a bushing would set the depth of the cut.. I’ve tried manualy setting the depth of cut and it’s always off 1/16” or 1/8” and read that bushings are used to control the depth of a cut
View bondogaposis's profile
bondogaposis
4524 posts in 2221 days
#5 posted 10-08-2015 06:24 PM
I’m baffled by your description.
The height of the box joint is controlled by the height of the bit, no bushing needed.
-- Bondo Gaposis
EdsCustomWoodCrafts
#6 posted 10-08-2015 06:27 PM
I m baffled by your description.
- bondogaposis
The depth adjustment on my router is extremely hard to adjust to minute increments so as to achieve a uniformed slots and fingers .. I’m trying to explain as best I can.. Outside my comfort zone on this excercise!! Sorry
MrUnix
6186 posts in 2069 days
#7 posted 10-08-2015 06:28 PM
My router table is homemade and it s extremely difficult in measuring depth cuts with the router I have.. I thought a bushing would set the depth of the cut.. I ve tried manualy setting the depth of cut and it s always off 1/16” or 1/8” and read that bushings are used to control the depth of a cut.
I’ve never heard of using bushings to set the depth of cut, and can’t even think how that would be possible – unless your definition of ‘depth of cut’ is different than the norm. Depth of cut is set by raising or lowering the bit relative to the routers base plate… or in the case of a router table, relative to the table top. Bushings are used to follow templates, keeping the bit a fixed distance from the template edge – which has nothing to do with how deep the bit is cutting.
It would help if you post a picture of your current setup so we can see exactly what you are talking about.
View HokieKen's profile
HokieKen
4594 posts in 1008 days
#8 posted 10-09-2015 08:42 PM
I’m with everyone else. I think you’re a bit confused by something you’ve read about how a guide bushing works. The only way to adjust the depth of cut is to move the cutter up/down in relation to the table top. If it really is that difficult to set the depth on your router properly, you have a couple of options. (1) You can make a depth setting gauge. Just cut a notch in the corner of a flat piece of wood that’s the depth you need and move your bit to touch it. (2) With box joints, you can leave the pieces a little long and set your cut depth a little deep. Once you’ve cut all the joints, you’ll have overhang at the joints. Just plane/cut/sand it flush. You’re box dimensions won’t be precise but if you make everything else to fit the box, it won’t matter. Just be certain opposed sides start out the same length and use the same depth of cut for all the joints or you’ll end up with a box that’s out of square.
-- Kenny, SW VA, Go Hokies!!!
EdsCustomWoodCrafts
#9 posted 10-09-2015 09:08 PM
Thanks everyon for your input into this question .. I guess I misunderstood the application of a bushing but they do sound very interesting to use with a hand held router …
Thanks again
