Band saw or Scroll saw - difference? What to buy?
Forum topic by snowdog posted 772 days ago 282 views 0 times favorited 7 replies Add to Favorites Watch
View snowdog's profile
snowdog
809 posts in 882 days
772 days ago
Topic tags/keywords: tools band scroll saw
I am a little confused about the different uses for these two saws. I know the fundamental differences between a band saw and a scroll saw (ones goes round and round :) and the other goes up and down. Sounds like a song <laugh>
Scroll saw
Bandsaw
I have a Jet 18” band saw that I use all the time for resawing but with the big blade on it is little use to me as a detail saw. Hence the reason why I am looking at a smaller tool. Any suggestions on what I should look at?
View WayneC's profile (online now)
WayneC
6061 posts in 996 days
772 days ago
It would depend on what your trying to do. The depth of cut on a scroll saw is pretty limiting. Have you tried a thinner blade on your Jet? You should be able to use a 1/4” blade on it. I would suggest tryong a finer blade on your Jet before buying another saw… (unless your planning to do scroll projects)
View cckeele's profile
cckeele
76 posts in 772 days
772 days ago
Bandsaw’s were primarily designed for resawing as scroll saws are designed for intricate fret work. Bandsaw’s are also known for bandsaw boxes.. I have Grizzly G0555 and I can put an 1/8” blade on it for scroll work but its hard to track and ofcourse there is no speed control. If your stock is less than 2” then its probably best to use the scroll saw especially if yours has a speed control on it and you want to do the fretwork. Leave the bigger projects for the bandsaw. They really are two entirely different machines. If your shopping around for a scroll I do not recommend pin types as they are very limited. Also do not under any circumstance by the Grizzly 20” scroll saw. Worst vibrations and blade drift I have ever seen. Check the reviews before you buy.
-- All donations should be made out to me and in the form of wood or tools ~Chris
View brad's profile
brad
135 posts in 803 days
772 days ago
I bought my scroll saw first, in my case a mistake (however this afforded me a ready excuse to purchase a band saw)..haha.
As indicated above the intended use will be the determining factor. Good luck!!!
-- Brad,--"The way to eat an eliphant is one bite at a time"
View Betsy's profile
Betsy
2386 posts in 795 days
772 days ago
I agree with Wayne – if you are not going to do a lot of fine work – just get a smaller blade for the bandsaw. Here is a link of a post I did on Sawmill Creek – Betsy Yocum Big minnow – little minnow 10-17-2004, 9:35 PM
You can do a lot with a bandsaw – but to do stuff this small you really need a scroll saw. I used to do a lot more scrolling than I do now, but if you get a scroll saw – check the amount of vibration. Each saw is a bit different. I have a Dewalt 20” throat saw and really like it. I was particular though and it took three trips to get a saw that’s vibration was not bad on. I’m not sure if I just got unlucky getting two DeWalts that vibrated or if I was just really picky. However, the DeWalt that is in my shop has very little vibration and I can do some pretty small intricate work with it.
If you get a used saw to try them out – definetly stay away from saws that require a pin blade – pin blades are hard to work with and are almost impossible to do a lot of intricate small inside cuts.
Hope this helps a little.
snowdog
771 days ago
I am not sure I know what a pin blade is. What are the other options for blades? The Hitachi I listed above seems to be a pin blade “Accepts pin end of plain end blade types” <laugh> that sure makes me feel dumb.
Maybes a small band saw is the way to go since I want to be able to do some detailed work without having to change the blade on the 18” band saw (primarily used for resawing).
I don’t think I have enough info to buy just yet. Dang that will make my wife happy <laugh>
View mot's profile
mot
4904 posts in 936 days
771 days ago
We had a pretty good discussion on this a few days ago. This might help you a bit. Linkage!
Cheers!
Tom
snowdog
771 days ago
Good info on the link. I think a small band saw may be what I need. Thanks guys
