A weighty question
« back to Joinery forum
Forum topic by Chucklesawdustman posted 10-08-2015 03:47 PM 515 views 0 times favorited 3 replies Add to Favorites Watch
View Chucklesawdustman's profile
Chucklesawdustman
1 post in 1162 days
10-08-2015 03:47 PM
Topic tags/keywords: move a 14 band saw question
I have been using my Delta Milwaukee 14 ” band saw (1947vintage) for quite a while , now I want to move it down 1 flight of stairs. I know I’m planning to break down the saw frame from the motor stand but I’m trying to guess the weight of the saw frame casting which I plan to jockey it using a sturdy hand truck. I will lift off the stand with a chain fall and strap it to the hand truck. Knowing the approximate weight I think maybe 2 guys can handle it. any thoughts ?
3 replies so far
View DrDirt's profile
DrDirt
4510 posts in 3942 days
#1 posted 10-08-2015 04:33 PM
This is what I have – - I know different from yours but
The shipping weight is around 200 pounds.
i would suggest a furniture dolley with the wide base, that they use to move refrigerators, with a strap to secure it.
Frame is still cast iron – - yours might be 40 or 40 pounds heavier, as your wheels are likely iron instead of aluminum, but 2 guys should be able to move it around. Taking it apart and lining it all up again sucks.
View hairy's profile
hairy
2782 posts in 3732 days
#2 posted 10-08-2015 06:36 PM
Do you have those steps that are just treads and stringers? Make sure they can handle the weight. I put in extra supports underneath before I started moving heavy tools downstairs.
I’ve taken 2 bandsaws down those stairs. I took off the table, and motor/base and took it down in sections. It’s not that hard, to me it’s worth the effort.
-- My reality check bounced...
View MrUnix's profile
MrUnix
7043 posts in 2399 days
#3 posted 10-08-2015 06:42 PM
Those saws are not that heavy (I’ve lugged my ‘50 Delta BS around by myself)... and they can be split into manageable chunks if needed. Even easier if you have a helper. At the very least, please take off the table before moving to prevent the trunnions from getting damaged (just remove the two star wheels and lift off).
