Tension cable between two wall studs - to hang acoustic panels
Forum topic by composermark posted 10-08-2015 03:44 PM 747 views 0 times favorited 8 replies Add to Favorites Watch
View composermark's profile
composermark
1 post in 834 days
10-08-2015 03:44 PM
Hey
Sorry this is my first post – so if I’m doing something wrong, I apologize and will learn.
So I’m trying to mount some acoustical panels on the ceiling in a tower block condo. Ceiling and floors concrete – but I’m not too clear on the structure between units. Anyway, we own, but I’m really hoping to avoid drilling into the ceiling to mount hooks – in case it is as complicated as I imagine.
However the walls are drywall with studs. So my idea is to run two tensioned cables between two sides of the room – anchored through the studs. And then suspend these 3-4 panels (at weight 10lbs each).
So I figure each anchor/stud (4 of them) would have to support at least 20lbs lateral or vector force.
I know studs can take the static weight of large TV screens – even ones that are on extendable arms. So I imagine this realatively small force won’t present a problem. So long as I promise not to swing on the cables.
But I appreciate if anyone can see this solution for suspending some acoustic panels might be a bad idea for some reason.
Oh, it’s a 9 foot ceiling in case you were wondering.
-- Mark, Los Angeles.
8 replies so far
View mahdee's profile
mahdee
3830 posts in 1639 days
#1 posted 10-08-2015 03:50 PM
Why not hang them like a picture frame, each on a stud? Your plan should pose no structural concerns.
-- earthartandfoods.com
View Ocelot's profile
Ocelot
1862 posts in 2510 days
#2 posted 10-08-2015 06:36 PM
If the cable is tensioned and then weights hung from it, the force (tension) in the cable due to the suspended weights will be related to the deflection angle. The more deflection you allow in the cable, the less force (tension) will be produced by hanging weight from it.
The force multiplier will be (I think) 1 / sin(deflection angle).
So, if the angle at the wall anchor is 5 degrees, the tension force will be about 11.5 times half the weight suspended (because there are 2 anchors). If deflection is 2 degrees, the multiplier will be approximately 26.7 times half the suspended weight.
If the anchors are near the ceiling, this force can be more easily transferred into the top plate of the wall than if they were positioned lower.
View bigblockyeti's profile (online now)
bigblockyeti
4882 posts in 1593 days
#3 posted 10-08-2015 07:30 PM
If you’re planning on running the anchors axially in line with the cable, they had better be anchored very well. It is theoretically possible, but realistically impossible to keep the cable perfectly straight, so plan on some sagging, how much is acceptable for your installation? Most of the force on wall anchors from flat screen TV’s is in shear, your application would be exclusively in tension and as a result would require more robust anchoring (think trying to pull a nail from a board sideways vs. straight out).
Ocelot
#4 posted 10-08-2015 07:42 PM
If you re planning on running the anchors axially in line with the cable, they had better be anchored very well. It is theoretically possible, but realistically impossible to keep the cable perfectly straight, so plan on some sagging,
- bigblockyeti
To not sag would require infinite tension in the cable.
-Paul
View SirIrb's profile
SirIrb
1239 posts in 1102 days
#5 posted 10-08-2015 07:49 PM
These. Love them and they can take the weight.
http://www.monkeyhook.com/
View Hammerthumb's profile
Hammerthumb
2810 posts in 1847 days
#6 posted 10-08-2015 07:55 PM
What type of building is this? Is the substrate for the level above concrete on metal pan? Are the wall studs wood, or metal. As you have stated that it is a tower block condo, I would think it is concrete on metal pan for the ceiling substrate, and metal studs for the walls. Metal studs would require reinforced blocking to hold the weight. How much weight are you talking about?
-- Paul, Las Vegas
View Daruc's profile
Daruc
460 posts in 1005 days
#7 posted 10-08-2015 08:47 PM
Just use a hammer drill and mount anchors to the concrete ceiling. It’s not hard.
View putty's profile
putty
1174 posts in 1478 days
#8 posted 10-08-2015 08:59 PM
Go to an insulation supply house, they will have insulation hangers that you can epoxy to the concrete, then stab your acoustic panels on them and use the clip to hold them in place.
-- Putty
