How do I achieve this Edge Profile?
Forum topic by splinterking posted 10-07-2015 07:10 PM 1188 views 0 times favorited 19 replies Add to Favorites Watch
View splinterking's profile
splinterking
67 posts in 1943 days
10-07-2015 07:10 PM
Hi all,
I’m have a profile in mind for the edge of a round tabletop for a side table I’m working on. The problem is I can’t figure out how to do this. It’s a fairly large profile. I’ve inserted a pic below that shows a silhouette of what I’m envisioning. If the top was square I could do it like a raised panel on the table saw to remove the bulk and then use hand planes, rasps and sand paper to round it as picture. However the circular nature of this top eliminates the table saw and I’m not sure how consistent a rasp would be going around. The only thing else I can think of is some type of panel raising router bit with a bearing, but I really don’t want to drop $75+ on a bit for this particular piece. So any ideas would be appreciated.
22” wide x .875” thick.
-- "Clothes make the man. Naked people have little or no influence on society." ~Mark Twain
19 replies so far
View Ripthorn's profile
Ripthorn
1454 posts in 2891 days
#1 posted 10-07-2015 07:19 PM
For a profile that large there aren’t a lot of options other than the router bit. If it’s a one off, you might be able to take it to a cabinet shop and have them run it through their shaper, but it might not be any less than the router bit. Alternatively, 22” round is such that some lathes could swing it on the outboard side.
View Richard's profile
Richard
1916 posts in 2597 days
#2 posted 10-07-2015 07:24 PM
For a profile that large there aren t a lot of options other than the router bit. If it s a one off, you might be able to take it to a cabinet shop and have them run it through their shaper, but it might not be any less than the router bit. Alternatively, 22” round is such that some lathes could swing it on the outboard side.
- Ripthorn
Yep , router Bit or a Lathe is my only idea as well.
View DIYaholic's profile
DIYaholic
19538 posts in 2581 days
#3 posted 10-07-2015 07:31 PM
A quick google search returned this….
http://www.finewoodworking.com/item/33189/video-clever-sled-for-curved-bevels-on-the-tablesaw
splinterking
#4 posted 10-07-2015 07:51 PM
Hey thanks for the link. I had done a couple searches myself and didn’t come up with that. I’d had a similar scheme in mind, but couldn’t figure out a safe, accurate way to do it.
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2276 days
#5 posted 10-07-2015 07:51 PM
If you had a long straight bit for the router, you could make a jig that held the router registered at an angle to the table top. Walk the router/jig around the table top, then finish it off with planes/rasps/files.
16272 posts in 4124 days
#6 posted 10-07-2015 07:54 PM
If I didn’t want to drop the money on a large router bit, I’d do it by hand with an orbital sander. Start off with 60-grit paper to hog off material fairly quickly, and progress to finer grits. If you keep the sander moving around the perimeter without lingering in one place too long, it’s not as hard as you might think to achieve uniformity.
View bondogaposis's profile (online now)
bondogaposis
4608 posts in 2257 days
#7 posted 10-07-2015 08:58 PM
You could do it w/ an angle grinder and a Kutzall disc to hog off most of the waste then fine tune w/ a rasp and sandpaper. The key is careful layout, first mark the edge w/ a marking gauge then scribe a circle on the bottom edge stay wide of those lines with the Kutzall and finish up w/ hand tools.
-- Bondo Gaposis
View crank49's profile
crank49
4029 posts in 2877 days
#8 posted 10-08-2015 01:22 AM
That table saw jig looked like the way to go.
Too bad the finished side of the top has to rest on the fence.
Otherwise you could put a pin in the center to rotate the table top past the saw blade.
splinterking
#9 posted 10-08-2015 03:13 AM
Yeah crack49 I agree the table saw jig looks good and my first line of thought was to use the hole left from cutting the top on the bandsaw to cut the bevel somehow, but like you said it just faces the wrong way. I think if I do the FWW jig and the round and refine it it with hand tools and/or a ROS then I’ll get it.
I appreciate all the input from everyone.
View Logan Windram's profile
Logan Windram
344 posts in 2368 days
#10 posted 10-08-2015 03:53 AM
Shaper, build a jig so you can spin that top upright against a helical tilted flush bit. I have a pic of someone doing it, I will dig it up and post
View wunderaa's profile
wunderaa
248 posts in 2109 days
#11 posted 10-08-2015 11:15 AM
Finishing the same thing today. Mark your lines around the circumference and use a trusty foreplane to get down to the lines. It’s not as easy as straight lines but quicker than sanding and more controlled than routing.
View SirIrb's profile
SirIrb
1239 posts in 1137 days
#12 posted 10-08-2015 11:25 AM
A shaper with insert tooling. Custom grind your cutter. weigh it and place a similar counter weight blank on the oppisite side. Think panel raiser. Also, you may be able to find a shaper cutter similar.
This assumes you have a shaper at your disposal.
View ChuckV's profile
ChuckV
3096 posts in 3433 days
#13 posted 10-08-2015 12:33 PM
Finishing the same thing today. Mark your lines around the circumference and use a trusty foreplane to get down to the lines. It s not as easy as straight lines but quicker than sanding and more controlled than routing.
- wunderaa
This is my opinion too.
I made three shaker pedestal tables with a similar profile on the round top. Using planes was very enjoyable, very satisfying, and not all that difficult. Be sure to mind the grain direction as you work your way around the circumference.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
wunderaa
#14 posted 10-09-2015 03:02 AM
- ChuckV
Excellent point, as I omitted that one! The grain will constantly change as you go. However, I’ll be done shaping with the plane well before anyone gets their router or shaper jigged up. ;)
View gwilki's profile
gwilki
180 posts in 1380 days
#15 posted 10-11-2015 01:09 AM
You could use the table saw jig idea, but attach a waste block to the face of the table top with turner’s tape. Put a T nut in the waste block, run a bolt though the upright of the jig into the T nut and rotate the top through the blade.
-- Grant Wilkinson, Ottawa ON
