| Forum topic by mski | posted 623 days ago | 3741 views | 1 time favorited | 30 replies | ![]() |
623 days ago |
623 days ago |
Fine Woodworking Recommends the Bosch 1295DK ($80) or the Klingspore KA1893 ($70). They both appear to be the same sander with different branding. -- We must guard our enthusiasm as we would our life - James Krenov |
623 days ago |
Festool has a really cool one that is dustless with the mobile base connected. It just has a hefty price tag with it but it really does an awesome job with 2 modes and the jetstream to vacuum up all that saw dust. -- All donations should be made out to me and in the form of wood or tools ~Chris |
623 days ago |
almost forgot if your looking for a bargain on an orbital than try the dewalt. I think it still runs for $49..Works great too. a lil bit noisy though -- All donations should be made out to me and in the form of wood or tools ~Chris |
623 days ago |
If you’re looking for 1/4 sheet, I like the Ridgid R2500. I have two of them. I’ve owned (read: ruined) a few others. The R2500 does a fine job of sanding and is reasonably priced, but what I really like is the dust pickup – it really works! I don’t see it in the LumberJocks store, but it’s reasonably priced at the borg. Whatever you decide, be sure you get one with a sealed switch. -- http://www.north40custom.com -- http://north40studios.etsy.com -- |
623 days ago |
I have a 1/4 sheet Makita, need something more aggressive, I’ll look at the Bosch, I saw the Festool video, it’s probably a good investment but way out of my $ range, I entered two of thier contests. -- MARK IN BOB, So. CAL |
623 days ago |
I keep dreaming about the Bosch…the only drawback I can see is the dust collection system uses replaceable filters in stand-alone mode. But you can buy an add-on for connection to a vacuum source. maybe Christmas… -- "Bordnerizing" perfectly good lumber for over a decade. |
623 days ago |
My favorite random orbit sander is actually a flat metal rectangle called a hand scraper. Here’s how the story goes… I refinished an oak dining table for a friend. I did a ton of research on sanders and a good article in a magazine recommended Makita after various tests. So I bought it and loved it. It seemed efficient and smooth. I spent countless hours sanding the table and gradually stepped down my paper grits finer and finer. It looked perfect! So I applied the stain and suddenly all the little swirling sanding circles popped right out. I was horrified. So I started over and sanded the whole thing again, being even more careful…. Consistent pressure, don’t force it, slow smooth strokes over the surface, gradually step down grits…. Same results. I had bought a scraper but never used it. I gave it a try and it took me about fifteen minutes to scrape the entire table. It was absolutely perfect, and way smother than even the 360 grit sandpaper had produced. And guess what, no dust, no mask, no vibration-numbed hands, and no noise from the shop vac either. I do like my Makita but it sits on the shelf a lot these days. so if you haven’t bought one yet, try spending $12 on a good quality scraper (and learn how to correctly use it) before you spend $150 on a sander. -- Check out my new website! http://www.blakeweberwoodworking.com |
623 days ago |
I have the Dewalt. Now, I haven’t used any other brand so I can’t compare, but I really like it. -- "Functional WoodArt" by Debbie, Canada (http://www.execulink.com/~yohan) |
623 days ago |
I have a cheap shave hook I bought for scraping glue and on small parts I’ve used it to smooth small imperfections and was surprised how well it did, maybe I’ll try a larger scraper, -- MARK IN BOB, So. CAL |
623 days ago |
Festool and Bosch are both excellent….........the rest, IMHO arent worth it. Like Blake says…...a cabinet scraper is way faster, does a nicer job and doesnt run up the hydro bill or the dust. I’m always so surpirsed to work in a professional cabinet/furniture shop and not one of workers has a scraper. That said I am always suspect of the words “Random orbital”, especially the “random” part. They seem to leave very distictive marks, swirls that all look exactly the same which in my opinion doesnt mean “random”. More like a consistant vibrator…..... I dont know if you have compressed air but if you do, and if it can crank out about 18 to 20 cfm, then I highly recommnd a pneumatic random orbital. They are night and day compared to the electric ones, faster, easier to feather, can be used aggresively and do a far better job. Good Luck |
623 days ago |
I have the Ryobi variable speed model that runs about $50. Have had no issues with actual performance or results, and the little dust collection bag works well as long as you empty it often so the cloth doesn’t become clogged. -- --==[ Pappy ]==-- |
623 days ago |
I would check out the Ridgid 6” random orbital. Have used them quite a bit and have no complaints at all with performance and dust collection. |
623 days ago |
I have a Porter-Cable and a DeWalt. They both do well. I also use scrapers but most of the time I need to get some production out. -- Thos. Angle |
623 days ago |
I have a DeWalt and like it. But I have had the same problems as Blake. Having just discovered card scrapers I’m going to give those a try on my next project. I just finished a cherry blanket chest and while I’m very happy with the construction, am unhappy with the finish as I can see swirl marks that after several attempts I could not get out. So I “settled” for what I had. Now I’m thinking of going back and redoing the finish using a scraper first. Just not sure if I want to tackle the big job again. -- My digits count! |
623 days ago |
More info on scraper http://www.taunton.com/finewoodworking/pages/w00007.asp Links to the scrapers that woodcraft sells http://www.woodcraft.com/family.aspx?familyid=20021 http://www.woodcraft.com/family.aspx?familyid=20022 Burnisher http://www.woodcraft.com/family.aspx?FamilyID=262&cs=5809 You will also need a mill file And for those of you who like videos…. A new video from Chris Schwarz http://www.craftsmanstudio.com/html_p/AV18-D.htm -- We must guard our enthusiasm as we would our life - James Krenov |
623 days ago |
There are lots of opinions on how to use a scraper. The burnisher costs more than the scraper. But a hardened steel drill bit will work fine. I don’t burnish, however, I found it is quicker to just file the edge flat and go right back to work. It cuts just fine without the fancy rolled edge. You must file every few minutes but it only takes ten seconds. -- Check out my new website! http://www.blakeweberwoodworking.com |
623 days ago |
Wow—- you guys probably just answered my questions I just posted. Wayne – I’ll look at those links tonight. A good friend of mine who knows more about fixing people’s bodies than woodworking went to Woodcraft 4 or 5 years ago and bought me a bunch of stuff that “looked nice” for Christmas. (Yes, she’s a good friend to have, although has more money then sense – but I’m not complaining! She’s married now and her hubby gets all these gifts now. :-( ) I’m sure the Woodcraft folks were laughing behind her back——they made a pretty good sale. Anyway, one of those things was a burnisher. It has set on my shelf since then. I never really knew what it was until I decided to get into hand tools. -- My digits count! |
623 days ago |
Thanks All, -- MARK IN BOB, So. CAL |
623 days ago |
Here’s another vote for the DeWalt ROS. Very functional and the dust bag actually collects dust! And cheap enough so that if it breaks – and it hasn’t – it’s no great tragedy. I’ve used DeWalt tools for years and never had any problems. Never even bought replacement batteries for the cordless drills. Are there better brands? Probably. Certainly there are more expensive brands. -- Bob |
623 days ago |
I’m with Wayne, but I think he meant Bosch 1295 DVS ($80), not Bosch DK. It was a tie with the Klingspor for best overall and was rated best value as well. I bought mine based on the review from Taunton / Fine Woodworking. Had it about 6 months and love it. If you don’t use the factory dust collection and choose to hook it up to a vacuum, it will most likely require an adapter or tweaking. I cut up a empty 2-liter Diet Coke bottle and used some duct tape to change the shape of the hook up. Problem solved. -- Jeff, South Carolina |
623 days ago |
I’m using a Porter Cable 5” with hook and loop disks and a small selection of scrapers. There’s an old B&D 1/4 sheet orbital that I’ve repaired several times, but hang on to it for…who knows why? I did use it though the other day, clamping it into the bench vise. The best advise I could offer is that cabinet scrapers can do a fantastic job but if you want sandpaper, definately go with hook and loop. -- Bob Vila would be so proud of you! |
623 days ago |
I also have two of the Porter Cable 5” ROS with hook and loop. One of them is a vairable speed and the other a fixed speed. I have had no problem with either one and they both work very well. -- Max "Desperado", Salt Lake City, UT |
622 days ago |
I have two Porter Cable’s both with hook and loop. Whatever you do get hook and loop. It’s so easy to change paper and reuse it. One of my PC’s has 5 holes and the other 8. I have used the 5 hole one so much I wore out the hooks and had to get another pad at Lowe’s. I have been using it for at least 7 years with no problem. -- Gary, East TX -- The longest journey begins with a single step. |
618 days ago |
I bought a reconditioned Porter Cable from Toolking.com for $50. I really like it ~ it’s smooth, quiet and easy to use and also has it’s own little dust collection port. The paper changes out as easy as velcro. -- life can always be weaved into a song. |
508 days ago |
i currently have a PC 5” hook and loop and im getting pretty bad swirl marks…. looks like small ribbons right? its alot worse on soft woods but its present on all of them… is there a tune up method? can power supply be an issue? replace the pad? i just finished 2 tables just to see them riddled with swirls after stained…. it really just took the life right out of me =( -- Aint nothin to it but to do it! |
508 days ago |
I finally got a Festool 5”, it is unbeliveable for finish and dust collection, you do however have to use a certain technique and proceedure for swirl free finish.
I know scapers, yada yada yada, there are alot of times a scraper is not the best tool. (try finishing a end grain chopping board with one). http://www.festoolusa.com/Web_files/swirl_marks_tips.pdf What I have found through scientific experiment WAS; (I had a lab coat on) -- MARK IN BOB, So. CAL |
508 days ago |
nice info, i think im in need of a new pad… and definatly guilty of moving to fast with the ROS =( ... will try more tomorrow… thanks =) -- Aint nothin to it but to do it! |
508 days ago |
Did you get the rotex? -- -John "Do I have to keep typing a smiley? Just assume it's a joke." www.flickr.com/photos/gizmodyne |
508 days ago |
I would add to what mski said: do not start with 60 grit. I never managed to get off completely the scratches left by the 60 grit paper. If I start with 80 than everything is fine (Blake, maybe this is what you were doing since you were getting scratch marks when done). When it comes to sanding corners (two pieces coming together at 90 degrees), a random orbit sander is unbeatable. For the rest I like to hand sand or use a scraper. I can actually handsand much faster a board by hand than with a sander (the trick is one sanding block/grit so changing the grit takes 1.5 seconds). In terms of a good random orbit sander, I have the Bosh 1295SDK. To make it work like a champ, I bought the vacuum adapter (2.50$ on Amazon or local Lowes) and I connect my shopvac to it. Leaves no dust at all and the setup is way cheaper than festool. What I do not like about the random orbit sanders is the vibration and the noise. Alin -- -- Alin Dobra, Gainesville, Florida |
507 days ago |
no the 125, couldn’t yet justify a $360 sander, I don’t think for what I do I need one, yet -- MARK IN BOB, So. CAL |
| Forum | Topics |
Woodworking Skill Share
2187 |
2959 |
191 |
668 |
158 |
Woodworking Trade & Swap
444 |
Coffee Lounge
1777 |
LumberJocks.com Site Feedback
432 |
