Can I use acrylic over polyurethane?
Forum topic by Rob posted 10-07-2015 05:10 PM 809 views 0 times favorited 2 replies Add to Favorites Watch
View Rob 's profile
Rob
216 posts in 3662 days
10-07-2015 05:10 PM
Hey Jocks! Quick question for you. I’m finishing two crokinole boards differently, one is plain and the other has a stain. On the plain I’ve used acrylic and on the other I’ve used a stain/poly. Both are waterbased. My question is, once I’ve got to the level of stain I want, I wish to continue adding clear coats; can I use the acrylic that I’m using on the other board? This would make life easier as I wont have to clean up my gun so much. Thanks for your help!
2 replies so far
View Mike's profile
Mike
406 posts in 2681 days
#1 posted 10-07-2015 05:17 PM
I’d contact the stain manufacture with this question. They are going to be able to answer this definitively. There are usually 800 numbers on the cans for tech support and questions.
-- look Ma! I still got all eleven of my fingers! - http://www.lepelstatcrafts.etsy.com - https://www.youtube.com/channel/UCppWfrYGXCr5lm9uW-Fpqqw
View Rob 's profile
Rob
#2 posted 10-07-2015 07:06 PM
I d contact the stain manufacture with this question. They are going to be able to answer this definitively. There are usually 800 numbers on the cans for tech support and questions.
- Mike
Thanks for the tip. I called and they are compatible.
