pals kit table saw
Forum topic by joez posted 10-07-2015 02:49 PM 982 views 0 times favorited 8 replies Add to Favorites Watch
View joez's profile
joez
120 posts in 2928 days
10-07-2015 02:49 PM
Topic tags/keywords: pals kit table saw
I have a 103.22170 craftsman table saw vintage, does anybody know have any experience with pals table saw kit regarding with this saw?
8 replies so far
View DIYaholic's profile
DIYaholic
19623 posts in 2700 days
#1 posted 10-07-2015 05:22 PM
I have no experience with PALS for that saw….
Have you looked at In-Line Industries website?
Have you called In-line Industries?
View Tony1212's profile
Tony1212
196 posts in 1760 days
#2 posted 10-08-2015 02:22 PM
I just put PALS on my 113.29920 which looks very similar to yours. I created a topic here.
I was able to get my saw to 0.002” with it, but I needed new arbor bearings and I filed my trunions out a bit.
I never did get around to that blog, though…
-- Tony, SW Chicago Suburbs
View toolie's profile
toolie
2134 posts in 2654 days
#3 posted 10-09-2015 10:28 AM
- Tony1212
FWIW, i got both of my 113 series saws to +/.001 without PALS. a little patience and understanding of how the truniuons are bolted to the table will enable you to align your saw for enough accuracy without PALS.
View joez's profile
joez
#4 posted 10-10-2015 02:49 PM
tony what size kit did you use?
View joez's profile
joez
#5 posted 10-10-2015 02:55 PM
I also have the 10 inch saw and the 8 inch saw is what Im already working on since its lighter. There is a difference in trunnions size in my opinion.
View EEngineer's profile
EEngineer
1103 posts in 3638 days
#6 posted 10-12-2015 02:39 AM
Yeah, there is a big difference in the trunnions between the 103’s and the 113’s. I owned both (the 103 went to my brother after I upgraded to a 113 – still in use).
I am with toolie here – I got both of my saws tuned to a gnat’s ass without the expense of PAL’s. I really don’t see the need.
View groyuti's profile
groyuti
45 posts in 983 days
#7 posted 10-12-2015 02:51 PM
-- Spammer in the process of being removed.
Tony1212
#8 posted 10-13-2015 04:00 PM
Had to check my amazon purchase history, but I used the 3/8” PALS on my 113.
I’m a bit envious of you all that were able to get such tight tolerances without the PALS kit. “Tony1212” and “patience” are nearly diametrically opposed. That’s why I get to work at 5:45 am rather than sit through rush hour traffic.
The only difficulty I had with the PALS on my TS is that the set screw on the right side (when viewing from the back) is impossible to get to with the allen wrench. It’s too close the side of the saw, so that got to be a bit fiddly. But I got through it pretty quickly and got the tolerance that I was looking for.
However, I do have to remake my cross cut sled. The cuts are no longer square.
