Planer to drum sander conversion
Forum topic by Herbiej posted 12-04-2009 02:16 AM 4343 views 0 times favorited 6 replies Add to Favorites Watch
View Herbiej's profile
Herbiej
66 posts in 3591 days
12-04-2009 02:16 AM
I have an old 5 hp. Bellsaw 12 in, planer. Is it possible to convert this machine to a drum sander. I have no experience with a drum sander. So I don’t know what speed the drum should turn. The drum is about 3” in diameter. Pretty wide cracks where the blades fit. Has anyone done anything similar?
Herb Wallace
-- Acts: 2:38
View GaryK's profile
GaryK
10262 posts in 4226 days
#1 posted 12-04-2009 02:27 AM
I have a Peformax 22/44
The motor is 1 3/4 HP
RPM is 1725
Direct connect to motor shaft 1:1 ratio
5” diameter Drum
Circumference = PI x Diameter
3.14159 x 5 = 15.70795 inches
15.70795 x 1725 (RPM) / 12 = 2258 surface feet/min.
That should tell you what your surface speed should be.
View Mark's profile
Mark
1817 posts in 3512 days
#2 posted 12-04-2009 02:31 AM
I’ve seen in a homeworkshop magazine how to turn your tablesaw into a drum sander. I’d show you if I had it but the idea was to take off your blade, then throw on a band that you can attach from the table saw to the belt sander model you build to put on top of your tablesaw so it spins the sander for you and from there you’re set to run wood through carefully by hand like its a planer.
-- M.K.
View Farley's profile
Farley
15 posts in 1889 days
#3 posted 11-17-2013 10:28 PM
Thinking of doing this. Have u had any luck with it?
-- for cuts --- ducts tape works when you just can't stop.
View BilltheDiver's profile
BilltheDiver
260 posts in 3123 days
#4 posted 11-18-2013 06:44 AM
I used to own the 8” Belsaw Planer. I would say the easiest way to do what you want is to sell the planer and buy a drum sander. I have a planer and a drum sander and they compliment each other nicely. Look around on Craigslist and you should find a used drum sander for a reasonable price if you are patient. That’s how I got mine.
-- "Measure twice, cut once, count fingers"
View Jim Finn's profile
Jim Finn
2688 posts in 3160 days
#5 posted 11-18-2013 02:55 PM
I have a “V” sander that I made from a kit from stockroom supply. It works like a jointer in that you push the wood over the spinning drum. Similar to a “Sand Flea”
-- No PHD just a DD214 Website> craftingcouple.com
Farley
#6 posted 11-18-2013 03:16 PM
I don’t think this conversion is going to be the one. I think I’ll make one like shipwright made using my shopsmith as a power head
