Ideal material for workbench top
Forum topic by FlagshipOne posted 10-07-2015 12:32 PM 1345 views 0 times favorited 12 replies Add to Favorites Watch
View FlagshipOne's profile
12 posts in 2264 days
10-07-2015 12:32 PM
I am planning a new workbench build and was wondering what wood type might make the best top? factoring in durability and cost effectiveness.
-- Some Dood in Virginia
12 replies so far
View chrisstef's profile
17254 posts in 2941 days
#1 posted 10-07-2015 12:35 PM
Whatever is cheap and available.
View dhazelton's profile
2722 posts in 2232 days
#2 posted 10-07-2015 12:38 PM
Maple. Or ash. Or plywood. Or a solid core door. How deep is your wallet?
15250 posts in 2553 days
#3 posted 10-07-2015 12:41 PM
Cheap and available is huge, Stef is right on, and that depends on where you are. So check the janka scales for wood that’s in your area and pick the best option for you. Could be southern yellow pine, could be one of the oaks. Many say the exotics should be used for projects, that’s up to you.
Check out the pics in the Workbench Smack Down thread for ideas on what various makes and woods look like, maybe that’d help decide, as the end result needs to be pleasing to your eye as well.
View JayT's profile
5554 posts in 2146 days
#4 posted 10-07-2015 12:57 PM
From Christopher Schwarz’s advice on Mistakes of First Time Bench Builders
3. Over-agonizing the wood types used
Any wood (even plywood) can be used to make a bench. The material should be cheap, easy to get, heavy (if possible), dry-ish and heavy (if possible). After a few years of use, your bench will look like every other used bench – beat up, broke in and awesome.
Notice that the first criteria for him is cheap. My main bench is SPF construction lumber. I also have a very inexpensive travelling bench made out of oak trucking skids that cost me almost nothing. Paul Sellers has built many benches from Home Depot 2×4’s. Find something cheap and use it.
View Ripthorn's profile
1454 posts in 2920 days
#5 posted 10-07-2015 01:03 PM
I used doug fir 2×4’s for mine. I prefer it that way, since you want the bench top softer than the woods you will be working with so your bench gets marred, not your project. Also, if it takes a ding, I don’t sweat it. Finally, it was cheap.
View bondogaposis's profile
4640 posts in 2286 days
#6 posted 10-07-2015 01:14 PM
I used poplar/ with ash to reinforce the front edge wagon vise area. It has held up well over several years so far.
-- Bondo Gaposis
View BinghamtonEd's profile
2286 posts in 2305 days
#7 posted 10-07-2015 02:07 PM
I used DF 2×10’s, pith ripped out, turned on edge, for a 2” thick top, with a 3.5” apron on the front. At the time, was cheap, and readily available. Shortly after I finished it, I met a local hobbyist with a mill that sells me maple for significantly less than DF costs. Oh well. So far, it’s worked out great for me.
View Andre's profile
1723 posts in 1741 days
#8 posted 10-07-2015 03:17 PM
I found some old Birch, bought some hard Maple to frame top and for Vise faces! Hard to tell the two apart except for some grain patterns on them!
View rwe2156's profile
2844 posts in 1416 days
#9 posted 10-07-2015 03:27 PM
Whatever you can get your hands on.
Generally I would recommend a hard, dense wood that when you pound on it doesn’t simply absorb all the shock.
Dense wood will also be more durable. That’s way hard maple, beech and ash are such common choices.
The only wood I can think of I WOULDN’T use is spruce – way too soft.
The one I’m using now is a piece of SYP bowling alley lane.
View ste6168's profile
252 posts in 1107 days
#10 posted 10-07-2015 05:42 PM
I used Teak, works great.
Just kidding, my current benchtop is made of a sheet of 3/4” MDF, cut down the middle, and sandwiched together. Works fine for now, but I do plan to build a “real” bench at some point. Will probably use ash for the top.
View HokieKen's profile
4669 posts in 1074 days
#11 posted 10-07-2015 06:46 PM
Right now, I use 3/4 utility ply topped with 3/4 Oak hardwood flooring. It was free and available when I needed it and it’s worked fine. I’m planning a new bench soon and will be using construction grade SYP because it’s cheap and readily available. Most of the “Gurus” (Schwarz, Sellers et al) rank those as the 2 most important requirements. I did some research into SYP’s properties also and it’s quite suitable. It’s relatively dense and hard and resists bending/breaking very well. If glued up properly, it will remain pretty flat based on most people’s experience too.
-- Kenny, SW VA, Go Hokies!!!
View SignWave's profile
440 posts in 2970 days
#12 posted 10-07-2015 08:13 PM
I built a workbench out of D. Fir, although SYP would have work as well. I chose D. Fir because in this area, it has fewer knots and only costs a tiny bit more than SYP.
If you use construction grade dimensional lumber, I strongly suggest buying longer and wider boards and ripping/cutting them to size. It will be much easier to get knot-free and relatively straight short boards from a 12’x2”x12” board than it will from a 8’x2”x4” board. The cost per board foot is about the same (although there seems to be a sweet spot around 2×10 being much cheaper than 2×12 right now).
Mine is from ripped 2×6’s, so roughly a 2 5/8” thick lamination. It’s plenty durable, but my next one will be between 3 and 4 inches. A couple things that I’ll also do next time is to avoid knots and to orient the grain in the same direction on the boards. Both of these will make it much easier to level.
I’ve seen some really nice workbenches, but I like having one that I don’t mind if it gets dented or stained. It’s a tool, not a piece of furniture, IMHO.
-- Barry,
