Box joint key!!!
« back to Joinery forum
Forum topic by EdsCustomWoodCrafts posted 10-06-2015 10:05 PM 784 views 0 times favorited 7 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
742 posts in 1220 days
10-06-2015 10:05 PM
So my technical question is can I only use 1/2” thick wood if I’m using a box joint jig with a 1/2” square dowel as a key
Please say no!!!!!!
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
7 replies so far
Gerald Thompson
856 posts in 2111 days
#1 posted 10-06-2015 10:08 PM
No!
-- Jerry
EdsCustomWoodCrafts
#2 posted 10-06-2015 10:19 PM
So my technical question is can I only use 1/2” thick wood if I m using a box joint jig with a 1/2” square dowel as a key
Please say no!!!!!!
- edwood1975
So how Dow I line up the joint lines so there flush
View darinS's profile
darinS
705 posts in 2744 days
#3 posted 10-06-2015 10:40 PM
If I am understanding your question correctly, the 1/2” square dowel is the spacer for the fingers of the box joint. Raise your blade up to the thickness of the board you are cutting, that should line up the sides. If you are using a router, have the lowest part of the bit at the thickness of the board.
I think I got all that right. I’m betting someone will be along shortly to straighten both of us out with the correct answer.
-- They say many people die because of alcohol. They never realized how many of them are born because of it.
EdsCustomWoodCrafts
#4 posted 10-06-2015 10:46 PM
Ohh its on the router table and yes I’m talking about the 1/2” square key
View TheDane's profile
TheDane
5351 posts in 3540 days
#5 posted 10-07-2015 12:02 AM
The thickness of your stock doesn’t have anything to do with the width of the key/finger/socket. Blade/cutter height is what matters.
View Grandpa's profile
Grandpa
3259 posts in 2552 days
#6 posted 10-07-2015 09:49 PM
The Dane is correct. He wins the prize today!
You can use any width you choose but the height of the cutter (whatever you choose to use) has to be the thickness of the wood.
TopamaxSurvivor
18163 posts in 3553 days
#7 posted 10-08-2015 02:04 AM
If you use a 1/2” square key on the table saw or router table, how will you keep the material flat on the table if it is cutting slots only 1/4” deep?
