acrylic blanks stuck on drill bit
« back to Woodturning forum
Forum topic by csnyderdvm posted 10-06-2015 07:34 PM 1437 views 0 times favorited 5 replies Add to Favorites Watch
View csnyderdvm's profile
csnyderdvm
20 posts in 1707 days
10-06-2015 07:34 PM
Topic tags/keywords: lathe turning tip
So I’ve trashed 2 acrylic blanks so far after the bit became stuck when drilling the hole. I tried chilling the stuck acrylic/bit in the freezer- couldn’t get it out. Both times I had to score the acrylic and split it with a chisel to get it out. Am I trying to bore too deep a hole before backing out to clear shavings? Am I taking too long to drill the hole and creating too much heat that results in getting stuck? I’m looking for some advice?
Thanks in advance!
Chris
5 replies so far
View Picken5's profile
Picken5
250 posts in 2660 days
#1 posted 10-06-2015 07:41 PM
I’ve never worked with acrylics, but I’d suggest the following: Slowing down the speed of your drill and backing out the bit more frequently to clear chips. Sounds like the chips aren’t being cleared quickly enough and the chips may be melting a bit while your bit is still turning inside the blank — which I imagine would be similar to “hot gluing” your bit into the blank.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
View CharleyL's profile
CharleyL
222 posts in 3333 days
#2 posted 10-10-2015 01:37 AM
Plastic materials require much slower drill speed and a bit that more scrapes the hole than cuts it. If you take a regular twist drill and grind small flats where the sharp cutting edge is and make these flats in line with the shank, the cutting edges will become scrappers while the twisted flutes will still remove the cuttings. Slow down the speed to keep heat build-up below the melting point of the plastic, and you should be able to drill holes without the melting and sticking problems that you are having. A tiny bit of water dropped into the hole as it’s being drilled should help minimize the heating problem too, but it makes a mess.
Don’t forget to properly re-sharpen the bit before returning it to the drill index DAMIKT.
Charley
View waho6o9's profile
waho6o9
8168 posts in 2545 days
#3 posted 10-10-2015 01:48 AM
Drill bits for plastic ^
View Vince's profile
Vince
1145 posts in 3397 days
#4 posted 10-10-2015 01:07 PM
I use an air gun to keep the bit cool while drilling, haven’t had a problem since.
-- Vince
View gwilki's profile
gwilki
196 posts in 1442 days
#5 posted 10-11-2015 01:20 AM
I use brad point bits with good success. The key, as already mentioned, is to drill slowly. Back out every 1/4” or so. I use a mix of water, alcohol and dish soap in a squeeze bottle to keep the hole cool and lubed. Also, cut your blank a bit long so that you don’t need to drill out the end. It will prevent blow out.
-- Grant Wilkinson, Ottawa ON
